Going From Catted to Catless
Old Jun 5, 2011 | 04:02 PM
Midnight00SS's Avatar
Question Going From Catted to Catless
Mite be going from having my Catted Y to having and off road Y, cause im having to much ground clearance problems, question is, if i change to the off road y, do i need to get a new tune or not?
Old Jun 5, 2011 | 04:10 PM
99Bluz28's Avatar
I don't think you would need to.
Old Jun 5, 2011 | 04:17 PM
projectX's Avatar
Noper - you don't have to but you will throw a DTC code
Old Jun 5, 2011 | 04:24 PM
Wut is a DTC code?
Old Jun 5, 2011 | 04:36 PM
strokerrace's Avatar
Diagnostic Trouble Code (Check Engine Light)
Old Jun 5, 2011 | 07:56 PM
99SSJarhead's Avatar
you'll need sims or a tune for the rear o2's. Otherwise you'll throw a code.
Old Jun 5, 2011 | 08:06 PM
99TransAmLS16Spd's Avatar
Not that we have our cars for gas mileage, but you will get a little better mileage with a tune after you go with the ORY. It will literally take the tuner 5 minutes, there are a couple of cat protection flags that will dump more fuel to protect cats. No cats = no reason to dump extra fuel, but it needs to be tuned out.
Old Jun 5, 2011 | 11:49 PM
gotcha well i have a full dyno tune on it now, so i guess i would have to get it retuned again
Old Jun 6, 2011 | 01:39 AM
Starz T/A 17's Avatar
It really depends, I know a lot of guys with LT's that have catted Y pipes that had the rear 02s tuned out and pretty much just had the cats to reduce rasp. But it really all depends on the tune, and with high flow cats unless your making over 500 hp there really not going to be a restriction at all, and if you go ORY you MIGHT gain 2-5 hp. So its really not worth the re tune unless your throwing codes.
Old Jun 6, 2011 | 06:21 AM
408ws6ta's Avatar
Im building an exhaust setup for my 408 and I plan to use the 3" fake cats. We do not have emmissions here but I want it for the visual check.
With 4" mufflex exhaust I have read that there is no rasp so Im keeping my fingers crossed.
Old Jun 6, 2011 | 07:54 AM
Steve Gunn's Avatar
Link?
Old Jun 6, 2011 | 11:19 AM
Yea im doing it for ground clearance cause i wanna lower the car eventually and cant rite now
Old Jun 6, 2011 | 01:25 PM
408ws6ta's Avatar
Originally Posted by Steve Gunn
Link?
Im at work so no link. Google Search for "non catalyic converter". They are on ebay too! They look legit but have a straight pipe in the center.
Old Jun 6, 2011 | 04:03 PM
Steve Gunn's Avatar
thank you.
Old Jun 6, 2011 | 04:51 PM
I should have been a little more clear in my post above. You do not need to have them tuned out, only if you want gas mileage very slightly better and maybe a tad more HP. Obviously the tuner would tune out the rear o2s as well.
If you do not care about the above, then there is no reason to have a tune done. The ONLY thing a rear o2 fault will do is fail you on emissions if you have to get the vehicle tested. Sims can fix this problem, but at that point you are probably close to the $$ amount of a simple retune. If you do not have emissions testing, you can drive around with the rear o2 faults all day long with no ill effects. However your SES light will be on, and it would be worth while checking it often in case another code were to pop up for other reasons
Old Jun 6, 2011 | 11:45 PM
gotcha yea im still debating on wut to do lol
Old Jun 6, 2011 | 11:50 PM
do you know if your original tune had the codes for the cats tuned out? I know a lot of people have them deleted from the PCM regardless of if they run aftermarket cats due to the sensitivity of the PCM with some aftermarket cats
Old Jun 7, 2011 | 12:18 AM
yea just found out the cats were tuned out anyways
Old Jun 9, 2011 | 09:50 AM
anyone running corsa catless on here?
