ASP alternator pulley in an A4 question
Old Feb 26, 2004 | 02:06 PM
bigeller's Avatar
Default ASP alternator pulley in an A4 question
A friend of mine has an ASP altenator pulley he's not using.. I have the ASP crank pulley on my car already.. For some reason I though the alternator pulley was only beneficial on an M6 car..
Will the ASP alternator pulley work ok with the ASP crank pulley on an A4 car? Will I gain or lose anything? HP? Voltage? What will it help if anything?
Thanks
Michael
Old Feb 26, 2004 | 04:00 PM
Griswold's Avatar
I had an asp underdrive crank pulley with the stock alternator pulley and was having charging problems with a mild stereo. Battery would drop really low with the stereo on and idling at stop lights etc. I switched to an asp overdrive alternator pulley and everything is fine now. No charging problems whatsoever. Just a thought
Old Feb 26, 2004 | 05:10 PM
BlackTA's Avatar
Wouldnt an overdrive pulley counter an underdrive pulley? you know, -1 + 1 = 0
Old Feb 26, 2004 | 10:10 PM
lsx24's Avatar
Sounds logical, but maybe the Alternater pully doesn't counter as much, so I would imagine it could be -1 + 0.5 = -0.5.
Old Feb 27, 2004 | 12:10 PM
bigeller's Avatar
Thanks so far.. Anyone else? Will I lose power?
Old Feb 28, 2004 | 10:07 AM
uLoSeAgAin's Avatar
Hey I have been having the exact same charging problems at stop lights with my underdrive crank pulley! Everyone told me to just but a new battery and it would fix the problem...is this a waste of money? Im just going to take the damn pulley off if the battery solution isnt going to help..?
Old Feb 28, 2004 | 10:13 AM
Griswold's Avatar
I would suggest getting an overdrive alternator pulley. It worked for me and it's cheaper than a battery
Old Feb 28, 2004 | 10:32 AM
uLoSeAgAin's Avatar
I plan on getting a small system soon and just dont wont to be having problems like this especially once I actually do put a little smapge strain on the car. Wil the battery actually fix it but just costs a lil more or is the over drvie pulley the only fix? Because my dad is not cool with me putting stuff on it to make it faster so I sneak everything i have on it..ya know how it is..
