is this LS6 intake? *pics*
Old Jun 14, 2011 | 03:14 AM
omarrakeen's Avatar
Default is this LS6 intake? *pics*
ive been trolling some junk yards and ive been considering LS6 intake next...i have seen some pics of the intake but i wanted to make sure because its out of a 2002+ caprice SS..here are some pics. also, can anyone please show me some pics of the ripped ribs to fit the ls1 coolant lines? i dont want to block off the rear cross overs....Oh and the best of all they run 100$ here, ill try to take it for less thanks.
EDIT: another question, should i buy LS6 throttle body too? or can i use mine? i want maximum gains, am going to port and polish mine eventually. what about LS6 injectors? i have the egr block off plates too so i think am set. advices please. thanks
Old Jun 14, 2011 | 06:37 AM
Bowtiedford's Avatar
wondering myself and subscribing
Old Jun 14, 2011 | 06:45 AM
epglxspooky's Avatar
From the bottom, it does look like it. But what is the casting number? That will help you know for sure what it is.
Old Jun 14, 2011 | 08:34 AM
omarrakeen's Avatar
crap i didnt check the number! altho it looks like it but i wanted to make sure. mayebe some one can verify. car is a LS1 2002+ caprice SS. theres a complete 2001 camaro there which has LS6 intake but am buying 2 with my friend thats why i asked. thanks all.
Old Jun 14, 2011 | 08:40 AM
01ssreda4's Avatar
Yep that's an LS6 intake. Flat bottom is dead giveaway.
Old Jun 14, 2011 | 08:48 AM
tpunk's Avatar
No need on the injectors or tb. You will need the coolant line and coolant plugs though so snag them if they are there. Also I'd get the ls6 valley cover to upgrade your pcv system while you have the intake off.
omarrakeen's Avatar
awesome man getting 2 for less than 200$ is a steal! any idea to fit it without buying crossover pipes or wtever they are called? i heard something about removing the ribs of the intake? thanks again
Old Jun 14, 2011 | 08:49 AM
01ssreda4's Avatar
You have to grind the ribs some and flatten your coolant lines some. No biggie.
Old Jun 14, 2011 | 08:51 AM
omarrakeen's Avatar
is it worth it to change vally covers too? thanks
Old Jun 14, 2011 | 09:07 AM
jg rider's Avatar
If you're talking about an LS6 valley cover, you won't be able to reuse the LS1 coolant line because of the nubs on the top of the valley cover. Even if you grind down the ribs on the bottom of the manifold. I've been there
John
Old Jun 14, 2011 | 09:32 AM
Damian's Avatar
LSX Mechanic
If it's an 01+ car, it's an LS6 intake. AFAIK, GM no longer used the LS1 intake after 2000.
Old Jun 14, 2011 | 09:58 AM
udienow's Avatar
you simply use a hammer and chizel to knock off the ribs... they r weak plastic and will snap off easily. Here is a pic of what exactly you need to knock out:
Old Jun 14, 2011 | 10:01 AM
omarrakeen's Avatar
^ i know but double checking wont hurt seems like am going to grind the ribs and thats it thanks for the reply guys. cant wait for a new mod
Old Jun 14, 2011 | 10:33 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Using a nice new sharp wood chisel, you'll be able to completely shave off the ribs. It WILL fit just fine over the stock LS1 rear coolant lines.
Old Jun 14, 2011 | 11:37 AM
Floorman279's Avatar
Yup ls6 intake....another way to check ls1 vs ls6 is to look inbetween the intake ports.......ls1 intakes have x shaped ribbings inbetween the ports while ls6 intakes have square ribbing
Old Jun 14, 2011 | 12:06 PM
01ssreda4's Avatar
The point was the coolant lines will not fit if he decides to use the LS6 valley cover because it has raised nubs. With an LS1 valley it will work.
Old Jun 14, 2011 | 12:36 PM
R6cowboy's Avatar
This ^ is what I have read many times over. LS1 coolant lines will fit using a LS6 intake (with ribs knocked off) and the LS1 valley cover. But the LS1 coolant lines will not fit using a LS6 intake and the LS6 valley cover.
OP- also upgrading to the LS6 valley cover is a good mod to do while swapping the intake. If you don't want to use the two rear plugs, I've read you can use two front crossover coolant lines, one for the front and one for the rear. I have not actually done this myself so if someone knows for sure you can't use a front crossover coolant line in the rear please speak up.
Old Jun 14, 2011 | 02:44 PM
omarrakeen's Avatar
am staying with stock valley cover finding an ls6 is near impossible anyway. thanks for the pic "udienow"
Old Jun 14, 2011 | 03:37 PM
R6cowboy's Avatar
Btw, when talking LS6 valley cover, it means all 2001 and later LS1. So all '01+ LS1's have the LS6 valley cover/PCV system and intake. Just incase you didn't know. The later '01+ style PCV system/valley cover is very beneficial to the motor and very easy to change over. Just fyi.
Old Jun 14, 2011 | 04:35 PM
99 DUKE'Z 28's Avatar
Damn 2 for less than 200?!?! Pm me quote on one!!! Lol
