Will 04 gto intake fit my 00 t/a?
Old 06-16-2011, 12:27 PM
Doubleaction's Avatar
Default Will 04 gto intake fit my 00 t/a?
A local guy on clist is selling a ls6 intake off his gto and was wondering if it will fit w/o a problem on my 00 trans am..
thanks!
Old 06-17-2011, 10:48 PM
Pontiacerator
RevGTO's Avatar
Yes, it will fit as long as you whack off the ribs on the bottom of the intake.
Old 06-20-2011, 02:54 AM
ls1 1990 VN's Avatar
WHAT THE F?
Any LS6 manifold will fit the LS1 without modifying
Old 06-20-2011, 04:19 AM
omarrakeen's Avatar
Originally Posted by ls1 1990 VN
WHAT THE F?
not totally right, he was right about choping the ribs of to clear the coolant lines. other wise you have to remove them and plug the rears.
Old 06-20-2011, 10:08 AM
LSX Mechanic
Damian's Avatar
All LS6 intakes from 2001-2004 are interchangeable with any year LS1 engine.
I wouldn't waste the time sanding down the bottom of the intake. You can make your own block offs for the rear and cross-over tube for the front by simply modifying the stock 98-00 tubes.
Old 08-20-2011, 01:44 PM
SSsoSIK's Avatar
How exactly do you modify the tubes so the bottom doesnt have to be sanded?
Old 08-21-2011, 02:43 PM
Pontiacerator
RevGTO's Avatar
No sanding necessary. You just take a hammer and chisel and whack the ribs off that go over the coolant line pathways. Takes about 10-15 and it's fun besides
Old 08-21-2011, 07:48 PM
SSsoSIK's Avatar
There's no risk in damaging the intake by just breaking off the tabs? I just picked up an ls6 intake for $180 with low miles and it came with rails and injectors . So I'm not trying to mess up a good buy!
Old 08-21-2011, 08:09 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Yeah there is a risk but if you use common sense while doing it you'll be fine.
Took me all of five minutes to do mine
Old 08-21-2011, 08:30 PM
That's MISTER MODERATOR
Paul Bell's Avatar
RETAIN the rear cooling lines.
Using a sharp wood chisel and a small hammer, gently shave off the ribs.
It's in the video in this thread I found in a search:
https://ls1tech.com/forums/generatio...old-video.html
Old 08-21-2011, 09:18 PM
bernarlitt's Avatar
As the others said yes it will fit just fine. I have one from and 04 gto on my 00 TA right now with no issues. Just shave the ribs with a grinder or use the chisel method.
Old 08-22-2011, 07:09 AM
c0ncEpT's Avatar
Keep the coolant crossover. #7 needs all the help it can get IMO.
