ls6 vs ls1 headers?
Old Jul 13, 2011 | 02:31 PM
z28oc91's Avatar
Default ls6 vs ls1 headers?
hey guys i have a question, my cousin has a ls6 vette and he was lookin for headers for it. im wondering since the blocks are fairly similar cant you just use ls1 LTs? i know the ls6 has the 243 heads on it and that is different from the (853, 241) on ls1 blocks but then if you put 243s on an ls1 block do you have to change the headers also?
Old Jul 13, 2011 | 02:58 PM
King Nothing's Avatar
The blocks and heads are the same, it's the rest of the car that's different. I wouldn't try puttin headers for an fbody on a vette or via versa, someone else should chime in soon
Old Jul 13, 2011 | 03:08 PM
joecar's Avatar
The headers have to clear the chassis/k-member which are very different between F-car and Y-car.
Old Jul 13, 2011 | 03:39 PM
ULTIMATEORANGESS's Avatar
Smile
i would think ls1 and ls6 vette headers are the same.
Old Jul 13, 2011 | 03:45 PM
JrodCamaro's Avatar
I believe I've heard of t being done, but I could be wrong.. Always do research, hopefully somebody will chime in that knows for sure
Old Jul 13, 2011 | 07:03 PM
z28oc91's Avatar
okay that makes sense, so they are the same but just structurally different
Old Jul 13, 2011 | 08:03 PM
Paul Bell's Avatar
That's MISTER MODERATOR
I thought your question was pertaining more to the exhaust port shape. Your opening post does not say you wanted to swap headers between the Corvette and the Camaro.
LS1 heads have oval shaped exhaust ports.
LS6 heads have D shaped ports.
I do not think header manufacturers have different port flanges available. They should all accommodate the largest ports.
Old Jul 13, 2011 | 08:35 PM
brianw401's Avatar
My stock LS6 heads did have the D shaped exhaust ports, but the header openings are round. All CNC ported stock, & my aftermarket heads have round exhaust ports due to greater flow rates of a round port over the D shape. However, I guarantee my corvette headers will not bolt onto an F-body due to the different suspension set up's & k-member locations.
Old Jul 13, 2011 | 08:56 PM
Paul Bell's Avatar
There's no way a F-Body header will fit a Corvette.
Old Jul 14, 2011 | 03:23 PM
R6cowboy's Avatar
Corvette headers will not fit an F-body and vise versa. LS1 and LS6 use the exact same headers.
Now (for informational purposes) the stock LS1 exhaust manifolds differ from LS6 exhaust manifolds.
Old Jul 14, 2011 | 03:27 PM
babbage1109's Avatar
Headers are car specific. Not block specific.
Old Jul 14, 2011 | 11:12 PM
INMY01TA's Avatar
no.....
