Restriction?
Old Oct 21, 2011 | 05:59 PM
99Bluz28's Avatar
Default Restriction?
I'm going to try installing one of these modified car chemistry exhaust inserts right after each header in a effort to reduce or eliminate drone in the 1000-1500rpm range. My only concern is if they'll cause much restriction if they do help with the drone.
So what do you think, a little or a lot of restriction, will it reduce or increase drone?
I look forward to your input!
Old Oct 21, 2011 | 06:03 PM
ULTIMATEORANGESS's Avatar
i would think a little so its not not totally straight through.
interesting part.
Old Oct 21, 2011 | 06:12 PM
happysem's Avatar
I don't think thats any worse than any muffler could be.
A lot of the rasp has to do with the Y pipe setup on these cars.
Droning is another story though.
Old Oct 21, 2011 | 06:31 PM
omarrakeen's Avatar
one way to find out!
Old Oct 21, 2011 | 08:58 PM
99Bluz28's Avatar
Well, try as I might after 2hrs I couldn't get the darn things to go in regardless of what I did.
Old Oct 21, 2011 | 10:12 PM
Blk98Vert's Avatar
Id run the XR1 to the back, swap to a different muffler or add some metallic cats
Old Oct 22, 2011 | 12:27 AM
99Bluz28's Avatar
I actually have a set of high-flow magnaflow cats, but I have yet to find a shop here in CA that'll install them.
That's why I'm looking at other options right now.
Old Oct 22, 2011 | 08:48 PM
Jay-P's Avatar
Thats what she sa... ah nevermind.
Old Oct 22, 2011 | 09:47 PM
youguessit's Avatar
hooker exhaust... little to no droning
