2 piece timing covers
Old Dec 8, 2011 | 10:19 AM
2nd Gen Fl 'bird's Avatar
Default 2 piece timing covers
Who has used Edelbrock's 2 piece cover? Any bad things about it? Any better priced ones that I'm not aware of?
Old Dec 8, 2011 | 07:36 PM
Legman's Avatar
I wanted to use the Edelbrock 2pc cover but it wasn't compatable with my Mellings oil pump. I could've ground on it some to make it fit but decided to return it instead.
Old Dec 9, 2011 | 08:00 AM
Quick Time's Avatar
Ours works with aftermarket oil pumps. Like our High Volume pump as well. Made of 6061 Aircraft aluminum. Billet CNC.
More info can be found here:
http://www.quicktimeperformance.com/Cover/index.php
if you are interested i can help you out with our cover and pump combo price. Email us at sales@quicktimeperformance.com
Old Dec 9, 2011 | 10:08 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
^^ That's the one I was curious about, but didn't want to screw up someone else's thread...
Old Dec 9, 2011 | 03:07 PM
Legman's Avatar
Not to over-state the obvious.....but it sure makes cam changes in the car a whole lot easier. No more balancer removal and as in my C5, no more steering rack disassembly.
Old Dec 9, 2011 | 05:51 PM
LS1-450's Avatar
Have you guys given it a good leak test, as in w/ a little crank case pressure? It's a great concept, but, I wouldn't want to be the guinea pig, if you know what I mean.
Old Dec 10, 2011 | 07:02 AM
99C5Coupe's Avatar
I have one with no leaks.
Old Dec 11, 2011 | 08:35 AM
Not dedicated to Edelbrock at all, just a decent price on those. More info the better, no matter what brand.
Old Dec 12, 2011 | 08:59 AM
Quick Time's Avatar
Had to look at our folder on the timing covers. I made these before the LS2s came out. Back in 2004
So i do not think you have to worry about being a guinea pig. I believe almost every LS Engine Dyno Mule has our timing cover on it.
Here is a video of a cam swap showing how easy the cover makes it so much eaiser.
Sorry for the cheesey music
Old Dec 12, 2011 | 07:24 PM
mebuildit's Avatar
I just bought the Edelbrock 2 piece, looks like a nice product like the QTP unit. I'll let you know how it works out.
Old Dec 13, 2011 | 09:02 AM
By all means, post it!
Old Dec 14, 2011 | 12:34 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
Tommy and Top Gun, two old but good memories...
Old Dec 19, 2011 | 05:53 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
I have been using the QTP cover for years with no problems/leaks - I can attest to the hi quality, and the cam swaps are MUCH easier
Old Dec 20, 2011 | 01:52 PM
mebuildit's Avatar
Well I just did a test fit of my Edelbrock 2 piece timing cover. If you run a double roller timing chain it will rub!!! So I'm going to take some measurements and see if I can machine down the cover to make room for the spacers that move the pump out. I'll take some pictures to show how I did it.
So here are the pictures, from what I did today. I wound up having to take out .135 off of the cover to clear the ARP bolts. Guess, the Edelbrock cover isn't meant to be used with a double roller set up.
Old Dec 21, 2011 | 09:36 AM
Old Dec 21, 2011 | 11:16 AM
1QUIKWS6's Avatar
Nice work!
Old Dec 21, 2011 | 11:21 AM
Quick Time's Avatar
Even though you spent the time machining for a double roller you will never be able to swap a cam out. besides the issue of the chain pushing the pump further out, there is no slack with the double row chain to give you enough room to pull the timing gear out.
And if you do actually get it out, good luck getting it back in.
Old Dec 21, 2011 | 11:29 AM
1QUIKWS6's Avatar
Yes, now that I look at it closer - the dividing lip on the Edelbrock is up higher than the QTP, plus the casting at the lip protrudes more into the cavity than the QTP does... - which would make it harder (if not impossible) to get cam sprocket off with the inflexible double roller
Old Dec 22, 2011 | 08:34 AM
mebuildit's Avatar
Well, what's done is done and I'd still like to see someone with a double roller do the same with a QTP do a cam change to prove that it could be done.
I'm not baggin on QTP, I'd just like to see if it can be done in case I need to change what I have to theirs.
Old Dec 22, 2011 | 10:11 AM
Quick Time's Avatar
Its not a cover issue. You just cant pull the chain off the sprocket. There isnt any room. Also why do you need a double roller chain in the first place. No need for it.
We run a single chain on our 8 second camaro
