Craigslist 243 head questions
Old Jan 22, 2012 | 07:36 PM
01CaMMMaro's Avatar
Default Craigslist 243 head questions
I found a pair of 243 heads on Craigslist. The guy says they are milled 30 one thousandths, I'm not too familiar with milling heads, is that a very big difference or just smoothing it basically to get a smooth surface? Will this effect rod length? Also the guy bought them for a project and isn't using them but he's not sure what car they came off of, the springs are silver. Possible to tell based on color of springs?
Old Jan 22, 2012 | 07:46 PM
1nasty86's Avatar
Turd Gen Guy
if they have silver springs they are possibly not the ls6 style 243 with hollow stem intake and sodium filled exhaust valves, depending on your application you should still be fine with them milled .030.. i had a set of 317's milled .040 and didnt have any problems... how much are they? lol if there cheap enough i might steal them from ya
Old Jan 22, 2012 | 07:53 PM
01CaMMMaro's Avatar
Cheap enough
Old Jan 22, 2012 | 07:55 PM
01CaMMMaro's Avatar
The guy said he thinks they are from a GTO
Old Jan 22, 2012 | 08:01 PM
1BAD02WS6's Avatar
30 thou isn't alot but it's more than a clean up. It really depends on your set up, cam size etc
Old Jan 22, 2012 | 08:11 PM
01CaMMMaro's Avatar
Stock 2002 LS1 cam
Old Jan 22, 2012 | 08:30 PM
1nasty86's Avatar
Turd Gen Guy
oh yeah your fine with a stock camshaft lol
Old Jan 22, 2012 | 08:51 PM
redbird555's Avatar
just make sure you get some new pushrods a .030 mill will effect your pushrod length but you should be fine running pretty much any medium sized cam with those heads should you ever choose to do so.
Old Jan 22, 2012 | 10:29 PM
wildcamaro's Avatar
Yea you will need to switch pushrods at minimum to use those heads...I would also very they are only a 30 mill and not too far to the point the intake won't line up...Craigslist ppl can be shifty just cover all basis
Old Jan 23, 2012 | 01:51 AM
Blk98Vert's Avatar
As said they should be fine, they just have regular valves. I plan on doing the same thing with my setup.
Old Jan 23, 2012 | 01:53 AM
sepsis's Avatar
$300 a decent deal for a good used set of 243's?
Blk98Vert's Avatar
Yep thats around the going rate
Old Jan 23, 2012 | 08:09 AM
01CaMMMaro's Avatar
$300 is the lowest I've seen. For low mileage, 40k or less, I've been seeing them for around $500. The set I found is $375 and 35k miles.
Old Jan 23, 2012 | 08:47 AM
Rare96LT1Formula's Avatar
$300 is a great price imo. If it needs any unexpected work, you got them on the cheap.
Old Jan 23, 2012 | 11:46 AM
wildcamaro's Avatar
Yea $300 good deal i got mine for $320 locally like 6 months ago...i used to sometimes see cheaper but the cat is out of the bag when it comes to LS's now, all you gotta do is drop one in and you are instantly a threat to everyone on the streets!!
