can you pull the oil pan off in the car?
Old Mar 12, 2012 | 12:18 PM
25thhawk's Avatar
Default can you pull the oil pan off in the car?
Thinking about putting a baffle in the oil pan. Currently have trans out, wondering if it is possible to pull the pan out or if I need to pull the k member or lift the motor to do it. Thanks
Old Mar 12, 2012 | 05:17 PM
JaYZeig's Avatar
you will either have to raise the engine, or lower the k member/take it off...oil pan is in there tight.
Old Mar 12, 2012 | 07:22 PM
25thhawk's Avatar
Kinda figured. Thanks
Old Mar 12, 2012 | 09:15 PM
01transampower's Avatar
If the trans is out unbolt it and it should slide out the back unless you tried. Its tight but im not thingking that tight i just dropped my pan not out but with it all the way unbolted theres a lot of room between the k member and bottom of the block
Old Mar 13, 2012 | 12:41 AM
Scott02WS6's Avatar
I don't think it will just slide out with the pick up tube as stated above, not 100% tho
Old Mar 13, 2012 | 09:32 PM
well if you unbol the pickup tube from the oil pump in may be possible but also not sure either on that.
Old Mar 14, 2012 | 12:21 AM
usafws6's Avatar
ls oil pans are baffled well already why would you want to go through the trouble?
Old Mar 14, 2012 | 12:54 AM
01ssreda4's Avatar
No, no, and no. The answer is no.
Old Mar 14, 2012 | 01:55 PM
Golf&GM's Avatar
Easiest way is lowering the k-member. This should give you some idea on what's involved. https://ls1tech.com/forums/generatio...-write-up.html
