PP 85mm Typhoon Intake Impressions
I've read about the casting flash, runner cleanup being necessary on most, numerous times. Without the bottom plate removed, the runners looked great so I thought about tossing the intake on without any cleanup. Just for peace-of-mind, I pulled the bottom plate and BOOM, I was hit with one of the worst looking casting I have ever seen. It looked like the mold shifted, hard edges sticking out inside the runners, flash all over the runner entrys.
What concerned me the most was that two of the pieces of flash that I ran my fingers accross simply fell off into the runner. Both were around the size of a pencil eraser! If these would have come loose in my new motor, PP would have been paying a hefty pricetag for a replacement.
The reason for going aluminum was for a big nitrous setup and backfire potential. The price was great but if you decide to go this route, REMOVE THE BOTTOM PLATE AND THOROUGHLY INSPECT BEFORE INSTALLING.
Also, I sent my concerns to PP via email and have had no response as of yet.
sorry about the thread jack op
I got a canned response from PP stating that this is the first one they have heard of with this issue...
I've actually read on some mustang boards about the same issue. Unfortunately, it was after the fact.
I want to make it clear that I'm not knocking the intake at all. This is intended to warn folks that bolting it on straight out of the box is not wise.
