For those who have not seen c2 guages yet come inside,, PICS!
I just installed my triple pillar guage mount as well as my c2 fuel pressure guage and c2 a/f guage. These damn things are bright as hell. check out the pictures. Im just doing alot of preliminary work to my car before the new motor gets here and these looked pretty cool so I snapped a few shots. Tell me what you think...
Originally Posted by DANSLS1GTO
Just curious, can you turn those off? That'd be way distracting to me driving at night. Or is this a track only car?
Dan
Dan
I was kinda thinking the same thing myself, they can be turned off because they are hooked into the dimmer but then my interior lights would go off as well. If its too bad I'll hook up a switch so I can turn the lights on/off.
Very nice!
How hard were they to install?
I just bought some Cobalt Gauges and I am a little intimidated to install these myself.
I have a Fuel Pressure and Boost Gauge.
Any info would be greatly appreciated!!
I wasnt hard at all to install them. the guage pod piller fit like a glove and with a drill and a dremel I got it looking pretty good. I also decided to drill through the firewall right below the master cylinder to give me easy access to the engine bay plus I did not have splice this way haha. The only other issue was wiring up the power, dimmer and ground wires which I tapped all into the stereo for that. I found a thread that had the wiring schematic for our radios which made that easy. I'll post that once I get home.
Originally Posted by Mike K.
I was actually gonn tap it right off the o2 sensor with one of those speec inc connectors
Originally Posted by XtinctHawk02
I was blinded by the pics.. i needed my ...
Those are very sweet though
yeah tell me about it. Its almost like the gates of heaven are opening up
Hopefully they stay cool and dont end up getting irritating as hell.
Oh yeah here is the wiring diagram for anybody who needs it.
Headunit wiring harness
Pin#............Color.................Function
1...............Grey..................Front Left Speaker -
2...............Tan...................Front Left Speaker +
3...............Dark Green............Front Right Speaker -
4...............Light Green...........Front Right Speaker +
5...............Black.................Ground
6...............Brown.................Illumination
7...............Grey..................Dimmer
8...............Pink..................Power Antenna
9...............Yellow................12V Ignition
10..............Orange................12V Constant
11..............NA....................NA
12..............NA....................NA
13..............NA....................NA
14..............Dark Blue.............Steering Wheel Controls
17..............Light Blue............Right Rear Speaker -
18..............Dark Blue.............Right Rear Speaker +
19..............Yellow................Left Rear Speaker -
20..............Brown.................Left Rear Speaker +
you need power +12 switches for the gauges.
you can get this from the radio harness, or the fuse box.
you need a dimmer wire for the lights, you can get this from the radio harness, or the fuse box "IP dimmer" fuse.
you need a ground for the system.
