I thought I had a miss!!!!!!
Specs:
04 LS6, 243 heads, ASA cam, Vic Jr, 750 hp
I'd be pulling the heads and taking a look. A leak down B4 U do that may help.
Shitty fuel from sitting? Injs clogged up?
I clean/flow injs that are in boat applications. They are, many times, so bad they have to be replaced....[Rusty].
Thanks for the reply.
What rpm dose your boat sit at for an extended period of time? Stock heat ranged plugs are ment for low rpm cruising where they tend to cool off. If you're sitting at 5k all the time they never get that chance. Also try a non projected tip, they tend to run colder at rpm as well.
Edit also go with a standard copper core plug platinum holds heat as well.
You are running to hot a plug.
the 5 at the end dictates the heat range. in autolites the lower the number the colder the plug.
in ngk's the higher the number the colder.
I would try a NGK tr7 to start. if that seems too hot, then go with a non projected tip plug. i can get you a number if needed.
If you want it in a regular V-power($2.89) here's the pt#BR7EF and stk#3346, these come gaped at .028" (0.7mm) but you can adjust the gap up to .040".
I'd say the secondary metering jets need to be upped to the next size, eg. if they're 68 now go with 70. Make a WOT blast, shutdown, and remove/read the plugs again to see how it's burning.
Get the BR7EF
Thats what i would run there as well. I run them in my sb car when sparying. I run autolite 103's na
rpm/deg
0-15
1000-28
1700-29
6000-36
I don't get over 5000.
