MTI tb noise
Old Mar 28, 2004 | 11:40 PM
SLP LS1's Avatar
Default MTI tb noise
Well put my MTI tb on a day ago and it makes a weird noise when I start it up, then eventually dies out. Seems as though it's the air passing through it, I'm not sure. Do you guys have any suggestions?
Old Mar 29, 2004 | 12:18 AM
SLP LS1's Avatar
Little help needed!
Old Mar 29, 2004 | 03:22 AM
smokin' joe 00 ss's Avatar
Which MTI T/B 90mm?
Old Mar 29, 2004 | 07:56 AM
00T\A's Avatar
Originally Posted by smokin' joe 00 ss
Which MTI T/B 90mm?
Not sure what it is Mine sounds like a blower at start-up.
I kinda like it,it only lasts for a couple of seconds.
Old Mar 29, 2004 | 07:57 AM
Fireball's Avatar
based on his sig...I'm guessing he has that new 78mm billet TB they have
Old Mar 29, 2004 | 08:04 AM
goinbroke's Avatar
My bbk sounds like a supercharger also. I don't know what the hell causes it but it seems to be pretty normal.
Old Mar 29, 2004 | 08:08 AM
00T\A's Avatar
Mabye one of the holes needs to be chamferd or counter sinked.
Like i said it only lasts for a second.
An yes mine is the 78mm.
Old Mar 29, 2004 | 01:26 PM
triumphman's Avatar
It's the idle air passage squealing. as the iac opens the noise goes away , i smoothed out the sharp corners in the iac passage and that helped.
Old Mar 29, 2004 | 02:41 PM
SLP LS1's Avatar
Yes mine is the 78mm. Some sites list it at 75mm as stock. I just thought it was abnormal. If you guys are getting the same supercharging sound when you start the engine up it must be normal. It does die out after a few seconds, I was just worried ya know. I PM some MTI guys from this sight and I will have to see what they say when they get back to me. I just hope it's normal!!!!
Old Mar 29, 2004 | 06:46 PM
Yea I know but I have'nt updated my sig to a 90mm setup yet and I was'nt sure if he had or not.
Old Mar 30, 2004 | 12:05 AM
SLP LS1's Avatar
Does anyone else have any information about the MTI tb or others that make noise?
Old Mar 30, 2004 | 07:36 AM
BAD XXX's Avatar
Nothing to worry about. When TB's are ported, the hole for idle air is reduced. Upon startup, the IAC motor opens to allow enough air in to maintain a good idle. As the engine stabilizes, the IAC motor closes, making the sound go away. Since the hole is smaller, the air being sucked in causes a whistling sound. It's even louder if you have a cam with idle tuning, since the IAC is told to open even more. You should hear mine when I start up. Not an issue.
Old Mar 30, 2004 | 02:12 PM
PREDATOR-Z's Avatar
My BBK the same. What Bad XXX said.
Old Mar 30, 2004 | 03:00 PM
SLP LS1's Avatar
Thanks guys for the info! I really appreciate it
