egr system delete
Old Jun 28, 2012 | 06:58 PM
hempstar420's Avatar
Default egr system delete
removed egr system on my ls1 and i need to plug that 1inch hole in the intake manifold right after the throttle body. any ideas?? 2 things i tryed almost got sucked in..stupid plastic manifolds
Old Jun 28, 2012 | 06:59 PM
might have posted this on the wrong forum my bad but still..any ideas lol
Old Jun 28, 2012 | 07:54 PM
TransamGCS's Avatar
egr block off plug its a plate with a plug ws6 store sells them they come in billet aluminum and black heres a link
http://www.ws6project.com/user_stor/...oducts_id=4789
Old Jun 28, 2012 | 09:23 PM
Decadence75's Avatar
Or you can use a 1-3/8" expansion plug from your local auto parts store for about $5
Old Jun 28, 2012 | 09:39 PM
wildcamaro's Avatar
Expansion plug is the way to go if looks are t a concern if they are go with ws6 store plate
Old Jun 28, 2012 | 10:21 PM
Russ K's Avatar
A 2002 & up 5.3 truck has an EGR block off plate that will bolt right up.
Russ Kemp
Old Jun 29, 2012 | 01:28 AM
thanks gonna go get an expansion plug tomorrow
Old Jun 29, 2012 | 01:32 AM
Maniac_64's Avatar
If you for some reason can't get ahold of one anywhere else, I bought a rubber block off at o'rially's. Pop it in and use like a 10mm to tighten it 'til it seals. Have had mine on for years now and haven't had a single issue out of it yet.
Old Jun 29, 2012 | 02:54 AM
bones_c's Avatar
My vote goes to expansion plug!
Old Jun 29, 2012 | 03:04 AM
JeremyKrauss's Avatar
expansion plug. painted black, looks like it came that way.
Old Jun 29, 2012 | 04:30 AM
2win_SS's Avatar
EGR plug from WS6.
Old Jun 29, 2012 | 07:41 AM
totalchaos's Avatar
frost plug in mine , cover in windshield glue just make sure it didn't leak and hide the plug
Old Jun 29, 2012 | 10:54 AM
BAT TA's Avatar
Active Streak: 30 Days
I used an expansion plug on mine, drove it like that for a couple years without any problems before I swapped to an LS6 intake.
Old Jun 29, 2012 | 11:02 AM
LS1121's Avatar
change the intake, at least at inspection time you can say you have a Newer model motor that does not require one rather than having to pay a massive fine for removing emission systems. Just something to ponder. Plus you will have more HP.
Old Jun 29, 2012 | 11:04 AM
LS1121's Avatar
also...did you have it tuned out?
Old Jun 29, 2012 | 01:35 PM
mjs1012's Avatar
idk why anyone would buy the late from ws6 store, just get a plug for like $2 from any autoparts store.
