LS6 Manifold Differences
Old Jul 3, 2012 | 07:17 AM
LS-ONE_DAY's Avatar
Default LS6 Manifold Differences
Doing some digging through old threads and saw some posts that the LS6 intakes on the 01-02 F-bodies weren't the same as the LS6 intakes on the Corvette and that that the F-body units actually made better numbers on the dyno...any truth to this or is it something that can just be chalked up to every car is different (not the intake itself), dyno type, temperature/weather conditions, etc?
There is a vette ls6 manifold for sale that I plan on purchasing so I figured I should find out for sure, I want to squeeze out as much hp as possible
Old Jul 3, 2012 | 07:47 AM
Bramlok's Avatar
From what I've researched on ebay, the Corvette Z06 part number LS6 manifolds seem to sell higher than average compared to Fbody LS6 manifolds.
As far as flow, I doubt there is any difference between the two.
Old Jul 3, 2012 | 08:09 AM
bww3588's Avatar
Corvette tax...
/thread.
Old Jul 3, 2012 | 08:26 AM
LS-ONE_DAY's Avatar
The Vette LS6 I'm looking at is the same price as the typical F-body intake
Old Jul 3, 2012 | 08:43 AM
badazz81z28's Avatar
That would be my guess....My LS6 intake off of an F-body has the Z06 part number.
Old Jul 3, 2012 | 08:50 AM
TransAmcoupe98's Avatar
There has been results of the f-bodies LS6 intake flowing better than the vettes. I am going to try and find something but I know Ive read that.
Old Jul 3, 2012 | 08:53 AM
LS-ONE_DAY's Avatar
Cool thanks!
Old Jul 3, 2012 | 09:04 AM
After looking at a few things, there were no posted dynographs, numbers etc. NUmbers between the two are negligent and ou would see a bigger difference in numbers with a weather change. Power difference is about the size of a **** hair.
Old Jul 3, 2012 | 09:30 AM
LS-ONE_DAY's Avatar
Haha good to know. I do plan on doing either a cam/nitrous build or a heads/cam build....h/c/n is an option but very remote. I don't like the idea of putting in a cage. I'm wondering at what point the LS6 is going to hold me back...before I found this vette ls6 for sale I was planning on buying a BBK manifold w/ 80 or 85mm TB.
Old Jul 3, 2012 | 01:13 PM
2win_SS's Avatar
^^^ dnt go BBK. go FAST! And about the LS6 I believe they are all made the same. Why would GM make 2 different molds? And 01-02 Fbody equip with LS6 will make lil less than 98-00 Fbody equip with LS6 because they had bigger cams... Anyone think of that? Only difference between LS6 intake is part#...
Like badass said... I also bought a LS6 from a 02Z and it had ZO6 intake number.
Old Jul 3, 2012 | 01:18 PM
LS-ONE_DAY's Avatar
For LS1 equipped cars cost/benefit wise, BBK is the best choice for performance and they look great. FAST are too expensive. BBK manifolds have proven to consistently outperform LS6 manifolds.
Don't even mention heat soak, it's
Old Jul 3, 2012 | 02:13 PM
2win_SS's Avatar
I never said BBK wouldn't out perform the LS6... and look wise... To each his own... And yes HEAT SOAK... lol.... FAST are decent... I dnt mind the cost... You asked what LS6 differences wer... Not what intake is better... Or how much a FAST cost...
Old Jul 3, 2012 | 02:33 PM
Exeodus's Avatar
Here we go........
Old Jul 3, 2012 | 04:00 PM
LS-ONE_DAY's Avatar
Right....I don't see where you're going with this lol. I just made this thread to see if anyone had any proof or could corroborate the rumor that LS6's off an F-body make more power than a Z06 LS6.
Old Jul 3, 2012 | 09:13 PM
2win_SS's Avatar
^^^well... They are the same.... You said your were thinkn about buying a BBK before you found LS6... I said dnt buy BBK. buy a FAST.... then you compared a BBK to a LS6... so idk where you got I was comparing BBKvsLS6... if anything I was comparing FASTvsBBK.... which is a no brainer... Get it now?
Old Jul 4, 2012 | 01:00 PM
LS1 Racing's Avatar
Heat soak of the intake is BS. The air doesn't spend enough time inside the intake to heat up measurably.
Old Jul 4, 2012 | 04:32 PM
2win_SS's Avatar
^^^ I dnt believe it either... I just said it cause he didn't wana hear it lol.... I run LS6 or FAST... Dnt want metal as my intake. GM/FAST didn't use it so I'm not... I have no choice for my Chevelle tho.... Until I drop a LS in there...
LMAO resident *******? How did u get stuck with that subtitle?
Old Jul 4, 2012 | 05:02 PM
bww3588's Avatar
AFR makes a small block composite intake...
Old Jul 4, 2012 | 05:14 PM
2win_SS's Avatar
^^^ interesting. Never seen em... I'd check it out but I wana go LS anyway... Whatever comes 1st
Old Jul 4, 2012 | 05:17 PM
bww3588's Avatar
Jegs part number.
