Unique Exhaust need QUIETER!
11.2:1 Compression 408, LT's, Y-pipe, single 3" pipe, !Cats, !Air, !EGR, Gibson crossover muffler with dual tailpipes.
PROBLEM: TOO LOUD! ...Wifey won't go for a cruise/dinner and I no longer want all the attention at parking lots, stop lights and mainstreets just trying to idle through.(
Evil stares from mothers and "LIGHT 'EM UP!!!
from every red-blooded male!!!) I already have an electric cutout for track & street fun anyway.
Researched and installed "quietest", a Gibson SS muffler, but only slightly quieter, with more Bass (awesome but didn't get the job done...)
SO. What do you think of these 3 OPTIONS? Other ideas?
Hopefully some real-world experience with your suggestions!:
1. Probably quietest: Dynatech or Magnaflow Metallic Spun Cat between the axle and cutout ( SEE IMAGE FOR LOCATION)
I know power will suffer but that's OK ( open cutout when I want ), but very worried it might run all rich and poopy... Will I have to run AIR injection back there to light up cat to keep from clogging up???
2. Probably not so quiet: Dynomax Bullet, Borla XR1, Cherrybomb or Thrush between axle and Cutout? Maybe 12" max length possible... SEE IMAGE FOR LOCATION.
My only experience with a bullet "resonator" was on my supercharged Z-28 with LTs, !Cats, etc. The bullet was behind the muffler before tailpipe tip (SOTL) - it only quieted a tiny bit with more booming bass )
3. Two bullets between the Gibson muff and tailpipe tips? ( After gas tank and before tips) ? If they can fit there.
Other ideas?
Money all spent, so replacing Gibson with something else is out. And YES I know I should have done a true dual system but, too late too!
Just Need the "Best Anti-Bang for the Buck" LOL !!!
Oh, here's my custom chrome cutout side pipe - made from a COT Nascar muffler section and oval pipe from Dr. Gas! Just did it for fun. Need to cut it up again and tuck it up higher for looks and more ground clearance.
THANKS!
Rambo Benson
Thanks but SLP dual duals is what I already had (SS) before I switched to Gibson. ( only slightly quieter )
I guess it's the high compression and XLR big cam that makes it so frikkin loud too!
Ram
Blk98Vert: Do I need to run AIR to spun cats? I don't see a fitting on the spun metallic cat ad images...I do have (best) Kooks headers and Y merge, but then again...I don't want to lose anything BEFORE the cutout. But do I agree your idea is quietest, a guy few years back did same on a 455 LSX Camaro, Kooks fabricated his exhaust for him.
00Bluz28 and Blk98vert: I like idea of adding a magnaflow bullet but AFTER the cutout if I can get one to fit there, maybe a 12", (I don't have my car to measure right now but click on the first thumbnail IMAGE above, tight fit but do-able?).
THEN if still too loud 99 Bluz28 suggests two Magnaflows #14416 (2.5" in/out 4" dia., 14" case L), in the tail pipes, polished (of course!) Need to make sure they fit, did anyone try it? I think they would look killer peeking out the back of my black rollcaged vert too!
Mean greeenZ, Blue98Z28, CamaroKing, OK that would be cheapest, just change out with Aerochamber or Magnaflow to replace the Gibson.... IF, IF, IF....this REALLY quiets it down? But THIS high compression stroker LS2 just seems to be way louder than most to begin with! What may be quiet on your car....not on mine? Several people said Gibson, along with Aerochamber was quietest in a previous thread (that is, compared to SLP Dual Dual)...So I gambled on that, but definitely NOT on my car!
86lxnotch: Great idea! Do they make a 10 second Prius now? Sign me up!
Thanks!
Rambo
Pretty much same sound deadening I would guess?
Hey I really appreciate all the quick help everybody!
Rambo
I like your idea to squeeze in tailpipe 5" diameters or - even better - ovals!
Stainless Steel OVALS:
I'll figure the ones with the most volume I can fit under there!
HP-2 Flowmaster HP-2 stainless steel Ovals - 4" x 5.5" x 12 or 18"
132 or 167 each!
Dynatech Split Flo 4.5 x 7" x 14"
100 bucks each
Borla XR1 7 7/8" x 4.5" x 12" Ovals
142 bucks each!
Magnaflow Ovals 5 x 8 x 14" - But I don't see a 2.5" in/out on Jegs though...and it's kinda thick at 5"!
THIN center/center or offset/offset REGULAR MUFFLERS might even fit...
Magnaflow Universal 4" x 9" x 14" center/center or offset in/out POLISHED stainless steel
75 bucks each
PROBABLY FIRST CHOICE FOR QUIET IF THEY FIT BACK THERE...
Pypes Race Pro or Violators 4 x 9 x 14 stainless
64 - 65 bucks!
Borla PRO XS 4 x 9.5 x 14 center in/out or offset in/out
OUCH! 154 Bucks each!!!!
I have a lift in my shop to play with this idea.
I plan to post photos when it's sorted out-
