Budget true duals?
Old Aug 15, 2012 | 11:48 PM
nastyiroc's Avatar
Default Budget true duals?
What parts should I buy such as mufflers and x pipe and have a shop bend the tubing. What mufflers are good for the street but still make good power? I have read other posts from years ago but would like your input thanks.
Old Aug 16, 2012 | 12:56 AM
67goatman455's Avatar
summit universal x-pipe and dynomax bullets. they wont need to make much pipe. about the cheapest you can do really
Old Aug 16, 2012 | 11:11 AM
Sladester2's Avatar
how much do you think that would cost for an exhaust shop to weld up?
Old Aug 16, 2012 | 11:15 AM
LS-ONE_DAY's Avatar
Depends on your location, best thing to do would be to call and ask or stop by one day to a couple local places.
Old Aug 16, 2012 | 11:45 AM
BigBirdLS1's Avatar
I had my true duals fabbed up from the headers all the way to the back. I paid $300 including mufflers and tips.
Old Aug 16, 2012 | 11:54 AM
Sladester2's Avatar
thanks
Old Aug 16, 2012 | 12:12 PM
smahlum_21's Avatar
What kit have people bought from summit? I see they have a narrow kit also assuming that would be a easier fit
Old Aug 16, 2012 | 12:28 PM
sic7camaro's Avatar
$15-$25 a weld.depends how many welds u need and the muffler shop u go to.
Old Aug 16, 2012 | 12:33 PM
jc98ss's Avatar
i have an awesome set of mufflers in the for sale section, they were on my true dual kit from TSP and already have the rubber bushing hangers welded on......they're from Classic Chambered with a full 3" inside diameter, will slide right in behind an x-pipe if you're planning on dumping before the axle.
Old Aug 16, 2012 | 10:52 PM
nastyiroc's Avatar
Links?
Old Aug 16, 2012 | 10:56 PM
nastyiroc's Avatar
Should I get flow tech or dynomax x pipe and what mufflers?
Old Aug 17, 2012 | 05:48 AM
CayenneRedV6's Avatar
Originally Posted by nastyiroc
Links?
Took literaly less than a minute to find -_-.
http://www.summitracing.com/parts/SUM-642130/
Old Aug 17, 2012 | 12:21 PM
nastyiroc's Avatar
The dynomax is cheaper....
Old Aug 18, 2012 | 11:41 AM
omc8's Avatar
Is that over the axel , do you have pics of your complete system ?
Old Aug 20, 2012 | 11:54 AM
BigBirdLS1's Avatar
This is not over the axle. It does however have a way to loosen the exhaust to lower it so the rear axle doesn't break the hanger when it's on a lift. I don't have pics of my set up but I WILL get them today and post them in this thread. This is 2.5 inch pipe too not 3inch. And ground clearance isn't bad at all. I am at factory ride height though.
File Type: jpg
Old Aug 22, 2012 | 04:56 PM
omc8's Avatar
I was hoping to see it up on a lift and shot from down under. I wanted to see the design of the complete system, just hard to tell much from pics down on the ground.
Old Aug 22, 2012 | 06:01 PM
nastyiroc's Avatar
I want to do a dumped setup... What mufflers will perform the best yet still be on the quiet side for the street? Also x pipe?
Old Aug 22, 2012 | 06:10 PM
Sladester2's Avatar
im going with sweet thunders!
Old Aug 23, 2012 | 12:40 PM
SSCamaro99_3's Avatar
Quiet will cost more than loud on average. Also, quiet usually requires a larger case, and space is at a premium under these cars. Cheapest is the universal X and bullets, it will just be loud.
Old Aug 23, 2012 | 03:56 PM
omc8's Avatar
True , the universal X dumped will be cheap, loud and does not take a high skill level to install.Disadvantages to this too much noise and exhaust right underneath you for a DD or car that your going to spend any time in at all. Real loud all the time gets old real quick IMO. And I have yet to see one that is not hang'n low. I like to see exhaust high and tight.
