Trailblazer SS Owners... RADICAL Gains from RADICAL Ported Intake!
#61
For those who have been asking, we are now able to Radical port the GenIII GM Truck intakes. Here is a link to a before/after dyno that was done on a stock 2001 GMC Sierra 1500 with a 5.3L engine.
https://ls1tech.com/forums/generatio...l#post17618696
#63
Go to http://peakspeedshop.com/Zen_Cart/ to check out our new online store.
Order intake manifold porting, throttle body porting, FAST products plus intake parts.
Now, you no longer need to wait while you ship us your parts for porting. Pay a core charge to get the most common LS2, LS3 and LS7 parts from our inventory and be up and running the same day! Core charges are refundable once we receive your cores back. Order online at our new store!
For more information on Peak Speed Shop Services, go to our regular website at http://www.peakspeedshop.com/ . You can access our store from there, too.
#65
Peak Speed Shop Porting Process
Some have asked about our porting process. Peak Speed Shop uses a three step process for porting intake manifolds and throttle bodies.
Go to our website at http://www.peakspeedshop.com/ for more information, or call us at 719-651-1952.
First, we use a steel crosscut bur for removing most of the material in key areas and to smooth transitions and ridges for better air flow.
Second, we us sanding rolls for smoothing out the area that had material removed by the crosscut bur.
Last, we using buffing pads to polish the work.
Unlike some businesses that do porting on the side, porting intake manifolds and throttle bodies is our primary business. We have earned a good reputation for quality work and service at competitive prices. Second, we us sanding rolls for smoothing out the area that had material removed by the crosscut bur.
#67
Put a Peak Speed Shop Gift Certificate on your Christmas list!
![](http://peakspeedshop.com/Zen_Cart/images/gift_certificates/gv.gif)
Apply it towards porting your intake or throttle body. Or, apply it towards any of the products sold at our store:
To order gift certificates, go to http://peakspeedshop.com/Zen_Cart/in...products_id=47
- FAST manifolds
- FAST and Nick Williams throttle bodies
- Cold Air Intakes
- Billet style fuel rails
- Fuel Injectors
- Torrent fuel lines
- SLP and Lingenfelter Mass Air Flow sensors
- Twin Turbo Kits
- and more!
#68
quick question if i ordered a fast 102 for cathedral port with a nick williams throttle body and i also wanted the porting is there any kind of package deal? also would you port the throttle body or just the intake? (not for a truck)
#70
Coming Soon From Peak Speed Shop!
102mm Radical Ported Intake Manifold for L92 owners
![](http://www.peakspeedshop.com/images/L92%20Radical102%20small%20RGB.jpg)
We have had repeated requests asking when the FAST 102 LSXrt truck intake manifold would be available for the newer GM trucks with rectangular ported heads. We haven't heard of any plans for FAST to put this into production. This has prompted us at Peak Speed Shop to create our own....
![](http://peakspeedshop.com/Zen_Cart/images/TBSS%20Inside%20B.jpg)
![](http://peakspeedshop.com/Zen_Cart/images/TBSS%20Inside%20A.jpg)
Porting intake manifolds and throttle bodies is Peak Speed Shop's primary business. We have perfected a method for completely opening up the plenum "tunnel" and removing additional barriers that restrict air flow in the 6.2L truck manifolds. This is in addition to porting the intake runners for better airflow. For the Radical 102, we also enlarge the throttle body opening on the intake manifold to accommodate a larger 102mm throttle body. We sell the Nick Williams 102mm drive by wire and FAST 102mm drive by cable throttle bodies for this application.
We will be ready to take orders very soon. You will be able to order from our inventory or can send your intake manifold in for conversion. Details coming soon!
Applications (6.2L L92 and L9H):
2007+ Cadillac Escalade
2009+ Chevrolet Tahoe
2007+ GMC Yukon Denali/Denali XL
2007+ GMC Sierra Denali
2008+ Hummer H2
2009+ Chevrolet Silverado 1500 Vortec Max
2009+ GMC Sierra 1500 Vortec Max
2008+ Hummer H2
#72
Order your RADICAL 102 intake, now!
The best way to get your L92 to breathe!
![](http://peakspeedshop.com/Zen_Cart/images/Rad102_L92_PkgSmall.jpg)
![](http://www.peakspeedshop.com/images/Rad102%20Plenum_TB.jpg)
(LS3 intake shown)
Packages start as low as $495!
Packages also available with Drive by Wire and Drive by Cable Nick Williams 102mm throttle bodies.
Order at our online store at: http://peakspeedshop.com/Zen_Cart/in...ath=65_127_129
Or, call us at 719-651-1952.
(LS3 intake shown)
#73
Just got this great note from a RADICAL 102 LS3 car customer!
“The new addition is great. I didn’t realize how choked up the motor was until the upgrade. I've gotten horse power gains of 23 with the porting and the new 102 throttle body. Thanks for all your help.”
Scott - Ponchapoula, LA – Radical 102, LS3
Car Owners, Order at: http://peakspeedshop.com/Zen_Cart/in...Path=65_68_130
Truck Owners, Order at: http://peakspeedshop.com/Zen_Cart/in...ath=65_127_129
#77
Listen to what this customer has to say about his Peak Speed Shop Radical ported intake manifold on his 4.8L Silverado....
“I got my intake put on, wow what a difference. I don’t have a dyno test but I do have a Diablo Trinity programmer so I’ve always done logs after every mod on my truck. Well the most grams per sec of air its ever logged was 230g/s and a soon as I put this intake on I logged it and it showed 240g/s. That’s a big difference. I could even hear it, it sounded like it was sucking a lot more air.”
Several days later….
“Hey bob, after the tune we got it up to 242g/s. That’s a big improvement. Also before I put the intake on my best 0-60 was 7.9. Now after the intake and the new tune, I’m sitting at 7.68. That’s damn good. Thanks a lot bob. I really appreciate it.”
Lon – Pineville, LA – TBSS Truck Intake Manifold Radical Ported for 2010 4.8L Silverado with full bolt-ons, exhaust and custom tune.
