Got my headers
Old Aug 23, 2012 | 01:34 PM
Sladester2's Avatar
Default Got my headers
Got my headers in the mail today! Stainless steel TSP LT's!
I know I will need gaskets, and o2 sensor extenders. Which block off plates will I need and what else? Wheres the cheapest place to get header bolts from? What else am I missing ?
Old Aug 23, 2012 | 02:19 PM
Sladester2's Avatar
to add to this, i am also going with 2.5 inch duals. how do i get them hooked up to the headers good with clamps?
Old Aug 23, 2012 | 02:35 PM
Arctic_Z's Avatar
Where at in South east mo?
You can find block off plates at the ws6store i believe. If you have a ls1 intake you'll need the egr block off also. Yes use the band clamps. I found some replacement header bolts on ebay for pretty cheap
Old Aug 23, 2012 | 04:19 PM
astro11271984's Avatar
Arent thoses race style headers with no air provisions i would just delete the air pump
Old Aug 23, 2012 | 04:37 PM
I paid 9 dollars at gm for brand new header bolts also
Old Aug 23, 2012 | 05:56 PM
Sladester2's Avatar
Ya race style. Do I need both air and egr block offs? And I'm in desloge about an hour south of stl. Near farmington. I guess you can reuse the stock bolts and gaskets or no?
Old Aug 23, 2012 | 06:34 PM
z-maro's Avatar
I will be selling a pair of almost new (less than 200 miles on them) O2 extensions, if your interested send me a PM. I am switching to Corvette O2's.
I reused my stock gaskets, but not bolts.
What size primaries did you get?
Old Aug 23, 2012 | 06:36 PM
djfury05's Avatar
I'd reuse the bolts but not gaskets. Go with GM MLS gaskets IMO.
Old Aug 23, 2012 | 06:46 PM
Sladester2's Avatar
I just got the 1 3/4 right now. Don't plan on makin to much power. Maybe a 228r and heads down the road and I'll pm ya
Old Aug 23, 2012 | 06:47 PM
Sladester2's Avatar
Also looks like I have a bolt broke off where the stock manifold is connected to the y pipe. Is that gonna be a problem?
Old Aug 23, 2012 | 07:45 PM
If there race headers you wont need block off plates id go with new gaskets reused mine and had a bad leak so had to take everything apart the mls are crush gaskets and lose there shape if u reuse them
Old Aug 23, 2012 | 07:47 PM
Sladester2's Avatar
Which block off plate for the ls1 intake tho
If u go with new bolts gm is cheap and they have changed the grade to a stronger bolt less chance of breaking
Old Aug 23, 2012 | 08:43 PM
reeperz28's Avatar
I got gaskets and gm header bolts and o2 extensions from ws6 store! And the best egr block off for your intake is ....get an ls6 intake ha. But if have to ws6 store has them 2.
Old Aug 23, 2012 | 10:29 PM
Sladester2's Avatar
getting ls6 lateeeeeeeeeeer
Old Aug 23, 2012 | 11:11 PM
Sladester2's Avatar
so I just need egr block off plate for the ls1 intake? Not air? or should I get something else to block it off? I need a list of all the necessary parts please!
Old Aug 24, 2012 | 06:01 PM
Sladester2's Avatar
? Anyone
Old Aug 24, 2012 | 10:37 PM
pferris's Avatar
for the egr all you need is the block off plate for the intake. the AIR you can just remove the entire system as the only use for the system was to heat the cats up quicker.
Old Aug 24, 2012 | 11:52 PM
csess's Avatar
If you remove all this beaware your ses light will be on untill you get a tune an get it all deleted out. It wont hurt just letting you know. Also use alittle copper gasket spray on the gaskets an anti seize on the bolts.
Old Aug 25, 2012 | 09:45 AM
Sales1@Texas-speed's Avatar
Like others have said you just need a block off for where the EGR went into the LS1 intake, and you can simply delete all the AIR components. OP feel free to give me a call Ill be happy to go over everything with you. I can also get you the bolts, gaskets, and anything else you might be looking for to complete the swap.
