head/cam combo (narrowed down to 2)
The first being a Lunati 230/238 .600/.600 113 LSA , Patriot Predator heads, paired with F.A.S.T. 102 intake and TB, Meziere electric water pump, and 3.90 gears. Now I have seen dyno numbers up to around 540 whp with this combination.
The second (which i think im leaning more towards, although its a daily driver, but i just LOVE the lopeyness) is the MS4 - with a 112 LSA - cam paired with PRC stg 2.5 LS6 heads, along with same supporting mods as listed above. I also saw proven dyno numbers of 549 whp with this combination, but my question is, how streetable is this cam with an M6?
Thanks guys!
Build your own: https://www.vengeancerd.com/ecart/pr...t-Applications
VRX/TF kit: http://tinyurl.com/VRX-Cam-TF-Heads
Link wouldn't work so I made one.
http://www.trickflow.com/partdetail....S-K306-515-460
Trick flow's heads/cam combo that's dyno proven 515hp/460Tq
Comes with all gaskets, pushrods, double springs, roller cam, the works... Fully assembled. As long as you have a ls6 or fast intake, and have it tuned afterward ur set.
Cam is 228/230 .585/.585 112lsa
Can pick up for 3200 which can be a Lil cheaper then buying things separately in the long run. And it doesn't get much easier than this
