Tsp stainless ypipe help
P.S. You may want to use a block of wood on each side of the pipe or some other material to spread the mash points of the jaws on the vice out so you aren't flattening in one spot but rather a wider area if that makes sense.
The old TSP y pipe was a piece. This one is nice and ohh so close to being as perfect as you can get with the exception of the fact it needs that flat spot.
