EGR on a 01 Z28?
Old Sep 7, 2012 | 09:29 PM
MR01Z28's Avatar
Default EGR on a 01 Z28?
Hey I was wondering if anyone could tell me where to be exact and what size the bolts are to take it off and try to clean it b4 I buy a new one. I had my friend put my car on his scanner and he said the code was for my EGR thanks in advanced
Old Sep 7, 2012 | 10:15 PM
2xLS1's Avatar
There is no EGR system on a 01. 2000 is the last year they were used.
Old Sep 7, 2012 | 10:21 PM
MR01Z28's Avatar
Thats what I was told a long time ago but I just googled it and it says there is a EGR on the back of the intake up under the cowl panel. it was to hot today to feel so in the morning I will see if I feel it I got pics printed out of what it looks like. But I have always read and been told 01-02 didnt have an EGR but the code I am getting is an EGR code.
Old Sep 7, 2012 | 10:27 PM
2xLS1's Avatar
There is an AIR system diverter valve behind the intake on 00-02s. There is no EGR.
Old Sep 7, 2012 | 10:31 PM
MR01Z28's Avatar
IM guessing that is what is wrong then. have you ever taken one out and if you have do you remember what you need to take it out? size wise?
Old Sep 7, 2012 | 11:12 PM
2xLS1's Avatar
There are many parts to the AIR system. You can't assume the problem is the diverter valve. What is the code number. The check valves above the exhaust manifolds are more prone to failure than the diverter valve. Could be the AIR pump itself or something as simple as a fuse.
Old Sep 7, 2012 | 11:20 PM
2xLS1's Avatar
Old Sep 8, 2012 | 09:02 AM
MR01Z28's Avatar
Now that you say that I dont think I have heard the air pump in a long time even before my ses light came on. thanks i will look into all that
Old Sep 8, 2012 | 01:25 PM
King Nothing's Avatar
it does the same thing, it recirculates less than 10% of the incoming air into the cylinder heads, diluting the air-fuel mixture with this already-burned gas and it brings the combustion temps down about 300 degrees because there is very little 02 left in the exhaust to support combustion. the pump just does it solely without the use of a valve and sending it right into the intake manifold, just pushes it into the lid EGR=exhaust gas recirculation same thing as your air system
Old Sep 8, 2012 | 01:53 PM
bww3588's Avatar
wow...no. absoutely not.
2 different systems performing 2 different functions.
EGR puts exhaust gas back into the intake tract bringing combustion temps down to lower NOx gases.
AIR puts fresh air directly into the exhaust stream, bringing the cats up to light off temp sooner on cold starts to lower cold start emissions.
The EGR operates under part throttle conditions usually at cruising speeds.
The AIR system operates on cold starts, usually for about 30 seconds to a few minutes, depending on engine temps.
Old Sep 9, 2012 | 06:16 PM
MR01Z28's Avatar
ok I heard my air pump today I was out with the t-tops out no radio on and heard it but it was not half as loud as it used to be. Could that be the problem?
Old Sep 11, 2012 | 02:19 AM
LT1RAY's Avatar
What is the actual code number?
Old Sep 11, 2012 | 05:22 PM
NVR_SPDS's Avatar
All the AIR system does is get the cats up to temp quicker. Once they reach the right temp, it shuts off and becomes dead weight.
It injects air into the exhaust stream, and thats all. Its a very common mod to just delete it all, and have the codes deleted.
Old Sep 12, 2012 | 09:04 AM
Roarin_8's Avatar
The only time you will hear the air pump is when you first turn on the car, like others have stated. No EGR in 01-02 on LS6 intakes. Post up the code as others have stated.
Old Oct 17, 2012 | 11:11 PM
MR01Z28's Avatar
I will get that code again this weekend And post it up there car has been sitting while. thanks
