NVUSZ28's Build Thread
Now since I've only been able to put 4000 miles on my car in the last 2 years, I figured that I'll keep more miles off of it, and install all the goodies I've collected over the last couple of years.Today started out like any other day. My goal, Remove the AIR system. What happened was "oh eff it, lets take it all off and put everything on it now."
Pictures to come really soon!
The whole time, I hear, don't break the Oil Pressure Sensor... What do I do?
A little preview of what is to come...
Took off the center console for some secret stuff too
I'm also looking into removing the PCV system on my C5 and installing a catch can. I found a lot of info in the catch can threads, but is there a better resource for learning how to remove the factory PCV system?
http://ls1howto.com/index.php?article=18
I feel like I always take 1 step forward, and 3 steps back. I took off the valley plate today, to find out my 2001 needs grinding. According to LS6 valley conversions, 2001-02 F-Body's don't need it. Well, talking it over with a good friend, he had to do it on his '01 as well. I'm thinking it has to do with the actual build date of the car. I know that mine and his were built in Nov. of 2000. Oh well, time to pull out the Dremel, rags, towels, shop vac, and patience. Also anyone ever break the scissor tool to take off your fuel line? Happened to me today...
Things are still for sale:
LID, 85mm MAF, Torque Converter, Manifolds, Cats, Y-pipe.
Everything looks to be progressing well, what is the scope of your build? Bolt ons? H/C? Good luck!
I finally get a day off to put my car under the dremel knife, only to have my battery die every 15 minutes. I charged the battery for an hour to only have the same thing happen time and time again. So I gave up after 8 hours of working on it. I'll leave the battery on the charger for the night and knock it out tomorrow after work. It was after the first time the battery quit, I had wished I spent less money on the corded dremel instead.
Before
During
End of day progress. I only have 2mm to go down and a clean cut at the bottom left.
Also, WHERE CAN I GET THESE PLIERS!!! ANYONE HAVE ANY IDEA!!! I NEED THEM!!!!
