how to go from FAST 90/90 to EFI intake & 4150 TB
After the PRI show this Saturday I had a change of plans. I am building a 1970 Trans Am with the LS1 (see link in sig) & I want the shaker hood scoop to fit & work properly. That being said I want to go from my FAST 90/90 setup on my LS1 to an EFI intake & TB. Problem is I don't know the easiest /cheapest way to do it with swapping over as few parts as poss....
Can I just get an intake & TB?
Do I have to get new fuel rails & injectors?
What else do I need?
As for intakes the only one I have seen ready to go is the Victor JR (#29085) with the EFI bosses drilled. I have also seen the GMPP intake (#88958675) but it is carb only (not drilled) so that is out. Am I missing any?
Next is TB. I have seen a few from Edelbrock (3878), FAST (307603), Accufab (4150) or a downdraft style 102mm from TIPS.
Next big question is what is the going rate these days for a like new FAST 90/90 setup going for these days?
This is pretty much what I spent on my setup........
This is what I ordered:
Part #
Scorpion 4150 TB $530
28095 Super Vic. $410
3638 Edelbrock fuel rails $110
TC1000U36 Lokar cable(cut to fit) $50
15152 Jegs throttle cable bracket $65
Fel-Pro Q13123 intake gasket $30
RGR501 fuel rail kit from Speed Inc. $110
9749 (2) 45* elbows $40
9849 Spectre carb hat $75
Total= about $1500
And sold my FAST 90/90 for $700..........
Part #
Total= about $1500
I forget which one I got but I'm about 99% sure it is a FAST90 as well. I don't remember as it has been in a box for the past few years waiting for me to build my new engine... I'll pull it down this weekend & take a pic JTBS.
BTW, I'm ready to sell whenever you are ready to buy
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
BTW, I'm ready to sell whenever you are ready to buy![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
LilJayV10 - you are right & good point. IIRC the Single Plane 4 Barrel Type Intake manifolds like a little more lift/duration to pull the RPMs up top. They usually give up some low rpm TQ compared to the LS6/FAST style intakes.
I'm going to run a F13 cam (230/232 .595/.585 114* LSA) & not trying for max effort HP/TQ or anything so I hope I won't give up too much street-ability... Does anyone know what the Victors typically give up in HP & TQ down low compared to a LS6 or FAST?
BTW I sold my FAST 90/90 setup this week so now I have the $ for the Victor stuff
If you look around, you can go much cheaper. I did
Super Vic and fuel rails new in box from the classifieds $425 shipped
Accel 4150 tb from race-mart.com on sale for $325 shipped
Fittings and hose from race mart was about $100
Making my own tb bracket to use stock cables and cruise
That's it, need to buy an air cleaner but you already have that so you should be able to do it for $1000 or so if you know where to look
BTW I sold my FAST 90/90 setup this week so now I have the $ for the Victor stuff![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
MM98 - thanks for the tip. So you think that F13 will be a total down low
What other cams are out there for single plane besides that EPS? That lift & duration has me worries for PTV clearance with a stock bottom end. Plus I would prefer something just a tad smoother that a lumpy 108 if possible. I understand there is no such thing as a free lunch & concessions will need to be made somewhere.
Grr - do you know what model your TB is? 74202s2 or 74202s3 perhaps?
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
