Need REALLY high heat plug wires, help
Old Jan 27, 2013 | 10:35 PM
parks450's Avatar
Default Need REALLY high heat plug wires, help
Ok so I have a 6.0l in my s10 and have a set of custom headers on it. About every 3-4 weeks I have a wire that gets burned through. I have tried stock truck wires, gto wires, and MSD wires, no luck EVEN with heat socks. Problem is #5 and #3 primaries come close together right after the header flange.
So what do you guys do for something like that? I am looking at a set of eBay wires that have short boots so the will stick closer to the block rather than between the primaries.
Here's a pic of the header:
Old Jan 28, 2013 | 04:35 AM
Always2Slow's Avatar
You won't like my answer but you need to buy the granatelli wires with the heat wrap they are expensive but the warranty is top notch (lifetime) i personally own these wires and can vouch for the quality of them and they have never slipped off.
Old Jan 28, 2013 | 07:00 AM
Paul Bell's Avatar
That's MISTER MODERATOR
^ I was gonna say the same thing.
I think he will like them as they're the last wire set he'll ever buy for this engine.
Old Jan 28, 2013 | 07:01 AM
Paul Bell's Avatar
Hey Parks, can you post up some pics of this engine installed?
Old Jan 28, 2013 | 09:21 AM
parks450's Avatar
Here are a few Paul, its In a s10 zr2. Does anyone have a link for the correct ones? I see 2 that are similar, I'm looking for the short style.
Old Jan 28, 2013 | 06:10 PM
Paul Bell's Avatar
NICE! I suppose moving the battery solved several problems at one time.
Thanks for posting!
Old Jan 28, 2013 | 07:12 PM
http://www.ws6project.com/user_stor/...s-solid-core-/ Here you go
Old Jan 28, 2013 | 07:33 PM
Paul Bell's Avatar
That's the stuff.
It'll improve your engine's response.
Old Jan 28, 2013 | 09:17 PM
Gray86hatch's Avatar
firecore50
rick will build them anyway you want them. best stuff out there
Tim
Old Jan 29, 2013 | 08:01 AM
10droped's Avatar
I'm running these got them from PCM for less and also have the Kevlar covers work great
Old Jan 29, 2013 | 08:06 AM
Paul Bell's Avatar
The Granatell set has a double fire sleeve. And better wire.
Old Jan 29, 2013 | 08:19 AM
10droped's Avatar
My bad I just reread and seen u tried the socks
Old Jan 30, 2013 | 07:54 AM
Redbull87's Avatar
header wrap + granatelli should be more than enough.my granatelli sat on my header fully hot and didnt do anything.awesome stuff..expensive initially but worth it
Old Feb 2, 2013 | 02:00 PM
Grimes's Avatar
Would you consider getting the header ceramic coated?
Old Feb 5, 2013 | 11:44 AM
parks450's Avatar
I already have them wrapped, problem is the wire sits between two of the primaries, basically touching both, so it's like a double whammy haha. I double sleeved my MSD so I guess we will see how long that lasts.
Old Feb 5, 2013 | 12:07 PM
LopeyZ's Avatar
I have a ZR2 also and always wanted to put a 350 in it but for some reason I really want the LT1. Anyway, I can see your problem with those headers... looks great but a nightmare to work around. Besides the jethot or ceramic coating which sounds like even that wouldnt matter... all I can maybe throw out there is getting an extra long wire that you can route safely around the header coming up from under the primary and yeah it wouldnt look great.
Old Feb 5, 2013 | 07:01 PM
parks450's Avatar
I thought about doing a 350 before I decided on a 6.0l, then I said screw it. I like the efficiency, power, and looks. Plus everyone does a 350, when I started only about 3 people had documented builds with a LS motor.
Old Feb 5, 2013 | 11:13 PM
LopeyZ's Avatar
Crazy question but did you see a fuel economy increase or decrease with the LS? Always thought the 4.3 was so inefficient that something like the 5.3 or LS derivative would actually improve the fuel economy.
Old Feb 7, 2013 | 03:39 PM
parks450's Avatar
Yep, lol I get around 24 on the highway compared to 17 with the 4.3
Old Feb 7, 2013 | 09:42 PM
WS6ICK2k's Avatar
Thats awesome and quite a bit more horsepower at the same time.
