looking for a FAST intake
Old Feb 2, 2013 | 02:44 PM
ws6guy27's Avatar
Default looking for a FAST intake
looking for best intake and throttle body and everything for my ls6 383. c/r is 11.5.1 has a stock ls6 intake ported and fitted to a 80 mm throttle body. needing advice. car feels resitricted
Old Feb 2, 2013 | 02:51 PM
6.0_GTO's Avatar
Are you running stock air box? Why not go with a fast 102...
Old Feb 2, 2013 | 02:58 PM
97camaroguy's Avatar
I have an ls1 383 which is the same as your ls6 and I run a 92/92 fast setup and couldn't be happier.
Old Feb 2, 2013 | 03:00 PM
ws6guy27's Avatar
yea its a stock air box. i just boght the car. he had to have certain inspections he had to pass. and theres a k and n and took out the fins on the box. just when i had it dynoed and driving it around it feels restricted. like i could get more power.
Old Feb 2, 2013 | 03:01 PM
ws6guy27's Avatar
camaroguy.. what kinda numbers are u putting down? my cam is a 620/624 lift and a 235/247 @.050 with 114 lsa.. custom grind cam
Old Feb 2, 2013 | 07:33 PM
ws6guy27's Avatar
heard that if u go to big it can actually hurt ur power. and make it lower. iv thought about the 92 and getting it ported bc my set up now is close to the 90 set up now. i wanna try get the 102 but idk if my motor really needs it.. im kinda stumped need ur guys help
Old Feb 2, 2013 | 07:37 PM
lemons12's Avatar
The whole "too big" with a 102 is complete BS. It would pick up power on a BONE STOCK 1998 car even if you ported the 102. And I don't mean peak power, I mean everywhere.
Jayplay (a mod) has a black mild ported 92 FS in the classifieds... 729$ shipped. It is a smoking deal IMO.
If I were you, I would be all over it. You can recoup most of that by selling your setup.. Then you just need a TB.
Old Feb 2, 2013 | 07:42 PM
6.0_GTO's Avatar
Find a 92 Fast like mentioned above and an LS2 throttle body with the adapter harness and you should be happy.
Old Feb 2, 2013 | 07:44 PM
garygnu's Avatar
you can sell your ls6 intake for $300+ on here.
Old Feb 3, 2013 | 07:52 AM
ws6guy27's Avatar
My ls6 intake is ported and fitted for the 80mm tb.. would that up the price much? Do I need to upgrafe my 36 lb injectors tp 42? What kinda power differemce would I see.im at 458..almoat 459.. want to get close to 500 rwhp range...
Old Feb 3, 2013 | 10:05 PM
theMOSTWANTED's Avatar
I will take your ls6 intake off your hands if and whenever you decide to sell it. No need to rush just keep me in mind if you do decide to sell.
Old Feb 4, 2013 | 06:43 AM
ws6guy27's Avatar
Inbox me your price for intake n tb. And wouldthe 92 get me close tothe 500rwhp range? Im going be using bout 125-175 shot. Prolly a wet shot be better. And woukd the 92 work okay withit all or shoukdi get the 102? Maybe portthe 92? Also thinking bout getting better heads and selling my stage 2 ls6 heads just give me the extra power.. my cam is 620/624lift and a 234/247 @ 050.. if u guys r wondering. Cr is 11.5.1 also with the heads now
Old Feb 4, 2013 | 06:47 AM
ws6guy27's Avatar
Gto. What numbers r u putting down with ur 383
Old Feb 4, 2013 | 02:29 PM
6.0_GTO's Avatar
Are you referring to me? I still have my LS6, Just added my FAST 90, LS2 TB and 228.232 Cam.
Old Feb 4, 2013 | 02:54 PM
Blackpanther99's Avatar
I would do 102mm all the way.
Old Feb 4, 2013 | 03:08 PM
ws6guy27's Avatar
Yeah gto and camaroguy.. curious see what numbers ur puttjng to the wheels and mostwanted inbixm ur offer on the ls6 set up and am curious what a new set og afr 215s would run
Old Feb 4, 2013 | 07:35 PM
garygnu's Avatar
you should consider bigger injectors.a fast 102 requires a different fuel rail and injectors.saw a old thread where Tony M made great power with a fast 90mm intake.
Old Feb 6, 2013 | 10:25 PM
6.0_GTO's Avatar
I just got it dyno'd. Before FAST 90 with all mods in sig, 399.2 whp, then added FAST 90 and LS2 TB and made 426 whp. I would say its worth it. This is a few days apart, same temperature, same tuner, same dyno.
Old Feb 6, 2013 | 10:35 PM
01cherryreds10's Avatar
Why do you think you need a bigger intake again? Is this an auto or manual car? If auto, do you have a stall converter?
Old Feb 10, 2013 | 03:38 AM
ws6guy27's Avatar
The car seems to be and feels restricted. I put down 458 to the wheels just figured with a 383 big cam would neef breath better then a ported ls6 and 80 mm tb. And its a m6. Built
