Ls1 intake to ls6 swap
Thanks
Justin
and as stated above, you will need block off plates to the AIR tubes going to the headers.
I would also get rid of the EGR/AIR if you don't have emission testing where you live. I made my own block off plates with 1/8 steel. I didn't get a tune after I did my ls6 intake install and EGR/AIR delete, however, it will set codes off. So if you don't like to see your SES light on you will need a tune. Frost has great mail order tunes, and at a good price!
It'll take just basic hand tools to complete the swap. Good luck and enjoy the bump in power!
When you put the new knock sensors in make sure theyre tightened to spec (15 ft lbs IIRC) and put a nice layer of gasket maker around the top of the cups for the harness so water and moisture doesnt get into the sensors.
This link wil show you how to do it.
http://ls1howto.com/index.php?article=5
