Redoing my 2002 z28
I got a little sidetracked on monday since it was such a nice day and went down to the lake with a couple of my friends, had a little photo shoot lol.
I did order some suspension components today. Today I ordered...
umi panhard bar
umi tunnel brace mounted torque arm with driveshaft loop
umi lower control arms with poly bushings and rotojoints
umi 3 point weld on subframe connectors
umi rear sway bar link
umi tower brace
slotted and drilled rotors (old ones were worn)
slp line lock
steel braded brake lines
Tomorrow I should here back from carl @ central racing parts on my quote for my driveshaft for the s60 and I also ordered some strange engineering rear adjustable shocks. Once I finish with the rear suspension I will be moving onto the front and installing the turbo kmember then the car will be getting some 6.0 love and a turbo!
I am really still trying to make the saturday test n tune even on may 4th at irp. I don't know if it will happen.
First off I received my new shocks today, still waiting on all my suspension components and driveshaft. I started pulling the rearend today it was much easier than I thought it was going to be!
I had to take this picture to compare the 10 bolt to the s60. It isn't as noticeable in the picture but the 10 bolt is much smaller compared to the s60
I am still waiting on suspension components like I said so basically I am just waiting till everything shows up. I am very excited to get the car back on the road and I'm ready to see what it runs at the track. I am hoping to hit a really low 11 sec pass.
I am hoping to get it all back together this weekend I also have to change the fuel pump. The stock one finally croaked I am surprised it lasted this long with the power this engine is putting out.
gsxr 600
So I am basically just waiting on the driveshaft for the car, I was really bummed I missed an even that I had really been looking forward to because the yoke was on back order from strange enegineering however it is all back together just waiting for the drive shaft to show up.
Don't worry the springs are in now, I had a brain fart....lol
Also since I like the way the ss hoods look way more than the z28 hood I thought there was no better time than now to upgrade the hood
I really hope to have the driveshaft this coming week so that I can get it on the track and get some video up since I missed my dyno day which is saturday
a little bit of the under the hood action. I have a problem with the fiber glass hood since I run a 104mm lid I have to cut the inner part of the hood out so that it will have enough clearance to shut. Other than that I really like the hood it looks just like an ss hood and taking I spent 400 on it I can deal with that.
I know know why but somehow the car sits about an inch lower in the rear now with the new setup than it did before. This makes little to no sense to me since I didn't change the springs but I like how it looks now.
Next up on the car is I just ordered a slp line lock for the car, and steel braided lines to put on. After I tackle that small project I am going to my next larger project of the k-member and upper and lower control arms. I am going with the turbo kmember for my little project that I am doing this winter.
I think after the kmember I will be ordering some weld rts wheels and tires and putting a nitrous setup on the car.
