Fast 92 and 92TB noob questions.
[IMG]
[/IMG] The first is what 99.9+% of people do and that's to remove the EGR System from their cars. I did this when I installed the LS6 Intake on my 1999 Formula. Its really simple to do. The EGR system mounts to the Passenger Exhaust Manifold/Header and you will need a Blockoff Plate to plug the hole once its removed. I had one made from some scrap steel, but I believe they can be purchased. Also removing the EGR Pump will result in an SES (Service Engine Soon) Light. An Aftermarket Tune from Frost can eliminate that.
Your second choice would be to modify your FAST92 to accept the EGR Tube. Essentially you would need to drill a hole in your $800 Intake, thereby removing any chance of ever selling it should you decide you want to.
Long-story-short. Ditch the EGR System, find a Blockoff Plate, bolt on your new Intake & TB and start saving for a Tune from Frost.
Who or what is this FROST? someone on the forum?
But this was not the reason for mentioning it in my previous post. I was simply stating the solution to the SES Light Problem that comes with removal of the EGR System.
The SES Light, in this case, won't affect the Engine's Performance, but if you're particular about your vehicle (as I am) and want to do the job correctly, a Tune is the proper way to eliminate the pesky DTC (Diagnostic Trouble Code).
I'd suggest you be damn sure you really need to retain your EGR System before you cut into that Intake. As I stated before, the moment you punch out that plastic to fit the EGR Tube, you are throwing any resale value out the window.
N hopefully that does give me some boost after some dodge with turbo looking thing beat me n some mustang idk what it was but it picked up quick n i thought to myself yes i brought shame to the TA. we need to mod for sure. A flock of birds flys together right!!
