Intermitant missfire and idle while in gear(auto)
Old Mar 15, 2013 | 01:44 PM
Birdoprey's Avatar
Default Intermitant missfire and idle while in gear(auto)
Hey guys, need a little direction here...
Just picked up a 99 T/A with A4 tranny. Car has 170,000mi on it and is very clean and looks to have been well cared for. The car runs great w/o any perceptable missing while driving. Idling good in neutral with a very occassional miss but nothing much. When i put it in gear idle drops to 400-500rpm and has an intermitant miss. Feels/sounds like a dead miss but its not consistant at all. Does it every few seconds, but its not regular at all. The previous owner told me he just replaced the plugs and it did'nt help. I just swapped out the AC Delco plug wire for a set of MSD's and this did not help either. If i bring the idle up using the throttle while its in gear it does not miss as much. The way it misses makes me think its an ignition problem. Def not the wires. Not 100% on the plugs but they did look like they had recently been changed when i swapped out the wires. Guess it could be a coil. There is no check engine light or anything.
Anyone have something simmilar? Thoughts?
Thanks,
-Mark
Old Mar 19, 2013 | 09:17 PM
1961ba427's Avatar
Sorry for not helping with your problem, but I gotta ask: What happened to your 93 Formula (Firehawk/WS6 clone) project?
Old Mar 19, 2013 | 10:28 PM
Birdoprey's Avatar
Well, after collecting about every part needed for a 500+ hp 383 LT1(built 700R4 tranny, Edge converter, Lloyd Elliot ported heads, etc), i realized that i did not have the time to complete the project anytime soon. I can't stand to have parts lying around and not able to work on it. Had family health problems that took up alot of my time then as well which to be honest really took the wind out of my sails on projects. Ended up selling it. I Loved the car but really liked the 98-up nose better and really wanted a LS1 motor. Had the opportunity a week ago to pickup this 99 T/A. Its in real nice shape and does not need anything, though the sickness i have to mod is always there....
Old Mar 20, 2013 | 12:47 AM
2000PewterT/A's Avatar
I would check the plugs again, time and time again I see people over tightening the plugs and cracking them only to cause a intermittent misfire. Also I had a set of brand new plugs in my dd for about 300 miles and then it started to misfire. I tested the coils, ICM, wires, with no problems found. I replaced the plugs and the misfire went away. The plugs were not over tightened they just went bad for some reason. Couldn't tell you why but never over look the plugs.
Old Mar 20, 2013 | 09:15 PM
1961ba427's Avatar
Is the car completely stock? It may not be so much a missfire as just too low of an idle rpm (while in gear) for it to run smooth. I'm not sure how you adjust that with an LS1 besides in the tune....or if something is wrong that is causing it to be too low. On LT1 throttle bodies there is a throttle stop screw that can be adjusted slightly.
Could there be a problem with your IAC?
Old Mar 20, 2013 | 09:25 PM
Birdoprey's Avatar
I'll have to check them out. Hoping to get a set of longtubes in the near future. Will be a good time to replace the plugs then.
Thanks for the info!
Old Mar 20, 2013 | 09:27 PM
Birdoprey's Avatar
Jason,
That was a thought for me as well. Took a looksee at the TB the other day and it has some build up. Gonna clean that out and see if that helps any. not sure if the idle can be adjusted w/o a tune. Will have to check into that.
Thanks for the suggestion!
Old Mar 20, 2013 | 09:32 PM
Altini's Avatar
Like 1961ba said there is a screw there u can adjust it but i doubble check the spark plugs and then the coils. Sometime a vacuum leak would feel like its miss firing. just a thought!
Old Mar 20, 2013 | 09:33 PM
1961ba427's Avatar
Hope you get it worked out soon.
I forgot to ask: Is the idle always at 4-500 rpm when in gear, or is that just what it drops to when it starts cutting up? If it's always that low then what I said above applies more.
I had thought about a vac leak too, but forgot to type that part. They usually give you a higher idle, but not always. While you are cleaning the TB, you might want to clean the MAF too.
Old Mar 20, 2013 | 09:43 PM
Birdoprey's Avatar
Thanks! I'll look into that as well.
Old Mar 20, 2013 | 09:45 PM
Birdoprey's Avatar
Jason,
It sits above 500rpm when not in gear. can't remember exactally where though. It drops a bit when put into gear and thats when the miss starts. I've not had time to mess with it. I'll look into it more this weekend if i get the chance. I'll post up what i find.
Thanks again,
-Mark
Old May 9, 2013 | 02:11 PM
shicledgend's Avatar
I have the exact same issue... normal idle is ab 850 rpms but when in drive (rarly) the idle will drop to 450 500rpms and thats when it starts to miss.... i just replaced my Opti 2weeks ago cuz it died... just changed the wires yesturday... spark plugs are good i pulled a few out and they look fine... i havent had a chance to scan it but im thinkin its an o2 sensor or EGR lemme no what you find and ill let you know if i figure it out soon
