need intake solution for SD tune
Old Apr 10, 2013 | 04:38 PM
red_cap's Avatar
From: Shreveport, LA (originality from Columbus, GA)
Default need intake solution for SD tune
i cant find any sort of intake tube to go from my slp lid to my fast 102 tb that does without the maf. is there anything out there for sale that is made for the connection or is everyone just fabing something up? could use some links or ideas with this one. thanks
Old Apr 11, 2013 | 10:04 PM
Blackpanther99's Avatar
I would go with the 98mn FTP Lid for your 102mm if your doing a speed density tune. Otherwise you can go with FTP's 104mm Lid.
http://www.afterthoughtsauto.com/fas...mm-airlid.html
Old Apr 25, 2013 | 10:27 AM
imma_stocker's Avatar
Texas Speed makes a 102 or 104mm lid. They might offer a larger MAF also if you want to keep one.
As for piping, that's really a fab kind of deal. Most that go this route have a laundry list of other engine bay mods that make a "bolt-on part" pretty much useless. I've completely ditched the lid setup and ram air box all together. Lots of fab work I'm hoping will pan out as planned. Never know til you try though.
Old Apr 25, 2013 | 07:44 PM
red_cap's Avatar
what im looking for is the connection between the lid and tb without a maf. some sort of silicone hose made for this set up.
Old Apr 26, 2013 | 02:49 PM
Highly doubt anyone makes a piece to drop-in your setup. Primarily because that lid is much smaller than your FAST 102mm tb, so your lid is your choke point.
An exhaust shop should be able to bend you a pipe for a decent price.
Old Apr 26, 2013 | 08:12 PM
VandykeT/A's Avatar
I'm running a 102mm TB, to 85mm maf, to a SLP lid. I used a fernco coupler from home depot to go from my TB to MAF. And the small bellow that comes with the maf to attach it to the lid. You could get a short piece of piping to substitute for the maf and do it the same way. Other than that I would check out intakehoses website or try googling 4" to 3.5" silicone hose (I think those are the sizes, measure to be sure).
Old Apr 26, 2013 | 08:16 PM
mikh338's Avatar
measure your o.d of tb and find a coupler that has a 22* bend that will connect to w e size piping you need to fit into your lid, that what i did with my sd setup. i can post a pic of mine if you wana see. i bought my coupler off ebay and a piece of aluminum piping. im in stock tb and a thunder racing lid tho so sizing will be differnt
Old Apr 26, 2013 | 11:30 PM
conan's Avatar
Here is a pic of my 1st procharger set up after going SD tune. I had to make my own pipe to fit. http://mycarpics.shutterfly.com/287#287
Old Apr 27, 2013 | 12:44 PM
Firebirdmuscle's Avatar
I bought a coupler from intakehoses. 4" diameter and 6" long went on good. Sd tune as well
Old May 6, 2013 | 07:06 AM
ss4chad's Avatar
That was EXACTLY what I was looking for!! www.intakehoses.com
Thanks for the tip!
Chad
Old May 6, 2013 | 10:27 PM
Glad that I could help.
Old May 7, 2013 | 12:29 PM
blown97ss's Avatar
I bought all my hoses from frozenboost. Way cheaper prices good hoses.
