anyone try one of these intakes?
Old Apr 28, 2013 | 09:38 PM
big hammer's Avatar
Default anyone try one of these intakes?
http://www.ebay.com/itm/170903363042...S:1123&vxp=mtr
they claim 17 more hp at 6200 rpm.
I asked them what kind engine they dyno'd it on and they responded
Thanks for contacting us. The dyno performed on this was on a stock LS6, against a stock LS6 intake. Similar, but not identical increases can be expected for the LS1's.
If your engine compartment is a stock 2002 LS1 this should be an easy fit except for the TB. Make sure you have a compatible throttle body for this kit. It requires a large-bore throttle body that has four bolt holes instead of the smaller TB's three-hole design. Have a great day!
Old Apr 28, 2013 | 09:52 PM
ULTIMATEORANGESS's Avatar
never heard of it though im interested if anyone has.
that runner design looks familiar so im wondering if its copying and selling at a lower price.
Old Apr 28, 2013 | 09:53 PM
HCI2000SS's Avatar
Never heard of it either. Interesting...
Old Apr 28, 2013 | 10:12 PM
Jay-P's Avatar
Looks like a copy of the typhoon intake... http://www.summitracing.com/parts/pf...0/media/images
Probably a chinese knock off.
Old Apr 28, 2013 | 10:15 PM
big hammer's Avatar
how does the typhoon intake perform?
Old Apr 28, 2013 | 10:17 PM
big hammer's Avatar
says this in the ad
Same as Professional Products part #52065 but much cheaper!
Old Apr 28, 2013 | 10:50 PM
Zlow28's Avatar
a member here bought it and iirc it dynoed higher than a ls6 intake.
OP, if youre considering that intake, check this one out too
http://www.ebay.com/itm/LS1-LS6-96MM-ALUMINUM-INTAKE-MANIFOLD-1500-6500-RPM-SATIN-FINISH-/120887887588?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c257ac6e4
They look identical and still cheaper. Also, contact them and they might lower the price. A member here did it.
Tbird232ci's Avatar
Professional Products is Chinese anyways.
Old Apr 29, 2013 | 12:09 AM
Blk98Vert's Avatar
There is no clear cut answer, some people say they gain, others lose. Anytime someone buys one and claims they will post results they disappear
Old Apr 29, 2013 | 02:19 AM
2000PewterT/A's Avatar
I have seen it perform make some power on some cars and loose on others being compared to a LS6. IMO I stick with the LS6, any more than that get a FAST.
Old Apr 29, 2013 | 05:20 AM
LS1MCSS's Avatar
It's a sad day when the Chinese start doing knock off's of their own ****. That manifold won't be any cheaper than the Professional Products manifold after you buy fuel rails. They come with the Pro Products.
Old Apr 29, 2013 | 07:02 AM
big hammer's Avatar
any gains from a fast 92\92 on a bolt on ls1?
Old Apr 29, 2013 | 07:56 AM
Blackpanther99's Avatar
On just bolts on I wouldnt go with a FAST because there wont be too much difference vs the ported LS6 intake. You will see more gains but not big enough to pay over $800bucks for the FAST.
Old Apr 29, 2013 | 08:02 AM
03Sssnake's Avatar
probably came from the same factory, these just fell off the truck on the way to the finishers
Old Apr 29, 2013 | 03:04 PM
MonmouthCtyLS7's Avatar
Looks like a typhoon, looks like they even used there dyno sheet if its a ripoff...had the 85mm here for years with no problems...will be keeping it for my turbo build also....like posted above after the rails it wont be any cheaper....get a LS6
Old Apr 29, 2013 | 07:08 PM
moeZ28's Avatar
It said in the description that the manufacturer is Pro Comp...its a cast unpolished version of a Typhoon intake. I like how the pic shows a rectangle port intake, but the gasket is for Cathedral port heads.
Old Apr 29, 2013 | 07:25 PM
jimmyblue's Avatar
Moderator
Professional Products gives you all you need except
the button-head valley cover screws. Gasket quality
is a big factor and they were dogged by that early
on, and fixed it; they even gave me the updated ones
for free when I got a kit with the old style. What are
you going to get from the eBay deal? Ready to go, or
a small parts headache?
Old Apr 29, 2013 | 08:14 PM
JakeFusion's Avatar
Super Hulk Smash
LS6 or spend for the FAST 102.
Old Apr 30, 2013 | 07:36 PM
Smile
i agree. or a 92 if available.
Old Apr 30, 2013 | 10:22 PM
big hammer's Avatar
I have an ls6 intake. just looking for the most power I can get out of bolt ons with my 2002 ls1.
