K&N vs Flowpac
Old Apr 29, 2013 | 07:15 PM
GHall8788's Avatar
Exclamation K&N vs Flowpac
Hey guys, i have a stock 2002 Z28 with slp lm. I am looking for a cold air intake, i want either the K&N cold air intake or the slp flowpac, does the K&N have heat soak problems? which is better?
Old Apr 29, 2013 | 07:20 PM
jimmyblue's Avatar
Moderator
You do not want the SLP Flopac, it's about the worst
of the CAI systems in every respect except the steel
construction (which is also responsible for most of the
problem, big-time heat soak). The K&N CAI, I haven't
seen up close but I'm against oiled filters on MAF cars.
I recommend a lid and a good hood - core support seal,
with some relieving of the "nostrils" to open up the air
path there (styrofoam needs trimmed, steak knife will
do). And relocation of the IAT to outside the engine
bay.
Do this and your air will be, and will read, same as
outside. And you'll save about a hundred bucks or
more.
Old Apr 29, 2013 | 07:35 PM
HCI2000SS's Avatar
IMO a SLP lid with a good paper filter, and a SSRA or Chris1313 is your best bet
Old Apr 29, 2013 | 08:01 PM
GHall8788's Avatar
besides the oil problem, does the K&N have heat soak problems?
Old Apr 29, 2013 | 08:11 PM
JakeFusion's Avatar
Super Hulk Smash
Don't go with that type of intake. The lid is the best intake you can put on these cars. Hell, a lid is the best type of intake on any bottom breather (see Corvette and the Callaway CAI).
Stop buying into hype. Those are a waste of money.
Instead, put an FTP 85mm if you want to run your stock or Z06 MAF or run SD. Or go with the 104 if you want to run a 102mm TB and 100mm MAF. Then add the Chrs1313 Ram Air to force feed the lid/box with cold, pressurized air from underneath the car.
Old Apr 29, 2013 | 09:30 PM
BWZ_2k2Z28's Avatar
^^^this. Paper filters are fine but you can use a aftermarket filter if you want. Just be careful to not put too much oil on it after you clean it.
Old Apr 29, 2013 | 09:50 PM
GHall8788's Avatar
Will the flowpac have heat soak?
Old Apr 30, 2013 | 12:23 AM
JakeFusion's Avatar
Super Hulk Smash
Flowpac is a very expensive kit. Just buy the SLP lid for 89, and the CHRS1313 ram air for 200. It's the same thing but cheaper.
And no - it's a true cold air kit. No heatsoak.
The K&N on the other hand is an open element sitting next to the engine. It'll suck in hot air. It also sits crooked in the engine back and doesn't align with the throttle-body. K&N did an AWESOME job designing that.
Old Apr 30, 2013 | 12:25 AM
libertyforall1776's Avatar
Post
I am going to call on this exaggeration - the SLP CAI brought noticeable pickup at highway speeds on both my SS & RS. Unsubstantiated claims on 'Tech don't fly -- so let's hear these "every respect"s?
Also, what do you mean by "core support seal"?
bay.
more.
Old Apr 30, 2013 | 03:29 AM
US_Army_Z28's Avatar
Running the flow pac as well, pieced it together from members on here, bellows, lid and the steel scoop, deff noticed a bit of pickup at highway speeds. Try and do the same, find people who have the kit used or buy bits and pieces here and there an you'll still save money, and as for the rubber seals and other hardware contact slp and they'll ship you all new seals and hardware for about 20 bucks, in the end I think I saved around 165 bucks if I remeber correct I think I paid 85 for the lid and bellows, 60 for the steel scoop then the 20 bucks for the seals and hardware new from slp. Do some parts searching and you can probably come out the same or better if you're lucky
