Want my camaro to sound like a mustang
#83
Okay so here’s what you need to do to make your v8 Camaro sound like a mustang!
Okay here’s what you need to do to to make your z28 sound like a Mustang! I did this on my 02 Trans Am. You need an off road Prochamber and duel 40 series Flowmaster mufflers. Obviously MAC doesn’t make the Prochamber for Camaros so fabrication is required. Remember no cats and try to get the mufflers to fit before the rear axle. All this affects sound. Yes ground clearance will be rough, but you will get as close to the mustang sound as possible. I was really pleased with my setup!!
#88
The following users liked this post:
03Sssnake (12-02-2019)
#89
Moderator
Received 1,838 Likes
I seriously thought this was a a troll thread
#90
I would bet the Mustang had an H-pipe. It evens the pulses for a fuller sound. Neither Vette had that, plus with sidepipes you usually only hear one side which sounds uneven and rough.
#95
Yes it did. It had an H pipe rather than an X pipe. Dual pipes running back to a single cross flow muffler mounted crosswise behind the axle. The sound was more of a low pitched growl. I loved that sound. Ford engineers did their homework on that one.
#96
But yeah, those early big block mustangs had a sound that was hard to beat!
