So I ported my Fast 90 to 92mm
After finding out that the 90 was the same thing as the 92, but with a smaller opening I knew I had to open it up. Then I figured, why stop there? Well I ported my Fast to get rid of the "wedge" and remove any casting marks on the top or in the runners. I didn't get into the middle or lower sections. I used a Dremel with a 60 grit drumroll to clean up the wedge, then hand sanded the ports and casting marks with 120 and 200 grit. I didn't want to use a die grinder or go too deep with the Dremel because it actually felt that I would be changing the design/structure of the runner. It has that hump leading up to the wedge where it helps compress the air and should help velocity. If you go too deep with a die grinder then you open the whole runner but it still bottlenecks back down, so it leaves sort of a chamber right before the port instead of compressing like the original design. SO you can still see where the wedge was originally but it's blended pretty well and since air comes off a slight hump from the inside I don't see the small slit being a problem. I'm going to touch up the port with some 400 grit to ensure it's truly flat and smooth, then clean everything with a brillo pad, soap, and water. Finally I painted the top because the grey was not cutting it. I thought about getting creative and re-painting the letters red, but I got lazy. I didn't change the port size as I want to port match the Fast to my heads and the heads are being cleaned and flow tested. So here it is.
Stock Port
[IMG][/IMG]
Stock Port vs Dremel cut
[IMG][/IMG]
Close up of Dremel cut
[IMG][/IMG]
Dremel cut from inside
After hand sanding
Another port after hand sanding
[IMG][/IMG]
Opened the snout out to 92.5 once i smoothed with sandpaper
[IMG][/IMG]
Finally I painted the top black gloss
[IMG][/IMG]
Stock Port
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
After hand sanding
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
You can't beat free!
Hopefully I get some more chances at it. It was quite fun.
I also have a 90 that's been ported to 92. I bought mine used and the previous owner didn't even know it was ported. No one knows who ported it but it appears very well done. I am also running a 92mm TB. I would think you'd pick up a few ponies - I wish I knew exactly what a port job like this would improve HP but I don't know of anyone who dynoed before and after with this being the only improvement.
So you got real lucky. Lol. Nice. My opening was actually a hair under 90mm. I think 89.75 or 89.80. I can't be quite positive. I think 93.5-94 is the widest you can go and keep the TB seal many bigger and you need to seal with silicone.
Mine is still sitting on the shelf next to my cam, springs and line lock. I can't hardly wait until I have time to install but I am kinda torn - I want to get my car to run 11.90 before I install the intake and cam. I hear great things about those Livernois stg 2 heads!
Painting in like 3-4 hours simply because you need to wait between coats.
Hmm...
Ive never actually looked inside my FAST even though I separated the top half and re-sealed it at one point. There was some hints that it might have been ported when the previous owner had it, and I keep forgetting to look. I kind of think its not touched...
If its not, Im going to port match it and do some work like you've done. I dont know if Ill open up to 92... I have a Nick Williams 90mm TB now, so I dont want to have to mess with that or step up if I can help it.
420gto (and others who have worked out the 90mm) what are you running for a throttle body now??
J.
J.
Hmm...
J.
J.
