About to install the long tubes.
Old Jun 29, 2013 | 07:25 AM
reinhardt02's Avatar
Default About to install the long tubes.
I think I have everything. Headers, ORY, header gaskets, header bolts, motor mounts, air gaskets, and I will re-pin the PCM plug to re-use my front o2 sensors with the rear o2 sensor harness. I still need spark plugs, but I will pick those up from the auto parts store. Should I get some kind of special plugs or stock replacements? Also plan to send the PCM to Frost for a tune. Am I missing anything? I know this subject has been beaten to death, I just want to make sure I got everything.
Old Jun 29, 2013 | 09:45 AM
ds98formula's Avatar
Sounds like you have it all
You doing this on a loft or jack stands
Old Jun 29, 2013 | 11:44 AM
jackstands. not excited. how high is high enough? 2ft?
Old Jun 29, 2013 | 01:13 PM
As high as you can go then higher lol.
Be safe. A buddy helped me with mine on a lift. I then had to take the passenger side one back off few years later do to air tube breaking off. I took it off on jack stands and it went pretty good but just have to try different angles to get them to slip in
Old Jun 29, 2013 | 01:45 PM
D14HUGGER.ORANGE's Avatar
On the passenger side(if you still have a/c) remove coil pack&bracket. Remove the two spark plugs closest to the front(it might even help quite abit to remove the passenger valve cover). Before installing passenger side header it will be easier to install #8 spark plug before you install the header.
Old Jun 29, 2013 | 02:11 PM
AmarilloWS6's Avatar
I bought MSD wires for my ws6 and my c5. The factory wires rip very easily if pulled on wrong. Any wire will work though, if you can get all 8 of the factory wires off without ripping them I'd just use those if you're crunched for money.
Old Jun 29, 2013 | 04:33 PM
The previous owner installed a set of MSD wires. They are at least 3 years old, I have had the car that long. But the car only has 35k miles, so I figure if I can remove them w/o damage then they should be good to go.
Old Jun 29, 2013 | 04:35 PM
You'll have to yank the MSD wires unnecessarily hard to rip them in half. Just pull them buy the gray boot that connects to the spark plug and they'll work just fine.
Old Jun 29, 2013 | 07:29 PM
Pull them all off by the boot inspect them all make sure there ain't any checks or exposed wire, if not they will be good to use again.
Old Jun 29, 2013 | 11:05 PM
Jvmun's Avatar
Should be pretty simple on jack stands just get it as high as you can. Safely of course. In my opinion the motor mounts were a pita mostly because my drill bits are very dull.
Old Jun 29, 2013 | 11:08 PM
Jvmun's Avatar
As far as spark plugs and wires. Ive always used AC Delco Iridiums and MSD wires. Ive switched to the NGK Iridiums no differences from what I can tell. What headers and ory did you choose?
Old Jun 30, 2013 | 02:31 AM
orthopod's Avatar
Get it high i used 12 ton jack stands. Have a friend up top and zip tie the gasket to the flange. Send the header up in its bubble wrap shipping bag to keep it scratch free. Get the collectors nearly perpendicular to the ground and play around with it and they slide right up. Make sure you have blocks of wood to use as supports for the motor mounts when you drill and sharp bits. Get the number 8 spark plug and the header bolts by it from the bottom. Keep all mm bolts loose until you get the main bolts through. Have fun.
orthopod's Avatar
Ngk tr55 at 0.045
Old Jun 30, 2013 | 08:08 AM
Thanks for all the tips guys. I bought a set of SLP stainless ceramic coated w/ Y pipe for CHEAP used on CL. I know, I know, SLP hang low but I couldn't pass up the price.
Old Jun 30, 2013 | 09:28 AM
cyberkill's Avatar
in case you want some instruction:
https://ls1tech.com/forums/generatio...otsa-pics.html
Old Jun 30, 2013 | 01:20 PM
excellent write up. I read that one some time ago and have been looking for that one to re-read before doing the install. Thanks.
Old Jun 30, 2013 | 09:24 PM
beyonddisturbed's Avatar
i just installed the ac delco iridiums and msd wires. Havent run her a ton yet but they seem to be nice. unless you are running an intense setup you are probably fine with stock plugs.
Old Jul 4, 2013 | 03:47 PM
Started the install this fine 4TH of July at 6 am right after I put the boston butt on the smoker. Done for the evening. What a PITA. I got all of the rip out done. Removed old shorty headers, y pipe, and broke down the motor mounts. Removing the rivets from the clamshells is harder than it should be. Solid rivets?! WTF?
Tomorrow I will run to the auto parts store to get plugs, the MSD wires checked out ok. Surprisingly I don't need anything else. I waited to go to the auto parts store until I finished the rip out to identify any additional parts I may need, but I don't need any! Amazing.
The boston butt is about ready, dinner gonna be FINE tonight. Happy Fourth of July everyone. Try not to blow any digits off.
Old Jul 10, 2013 | 07:50 PM
02 NHRA's Avatar
So did the install go ok?
I'm trying to get as much feedback/info as possible. I am planning on starting my LTs/ORY install next weekend. I'm not sure if I will be able to get the car high enough and might have to undo MM and rock the engine.
Old Jul 10, 2013 | 08:27 PM
Where at in Illinois are you
