Questions about future plans
Here are the mods that I have planned for the car:
American Racing Headers 1 7/8"
Kooks True Dual Axle Back
FAST 102 Intake and TB
FAST Fuel Rails
102 MAF
Volant Intake
I'm not really looking to cheap out on the car as, like I said, I would like to make it into a show car and it will probably stay low on the miles, while still getting driven a good amount.
I would also like to go fairly 'big' to leave room for heads and cam in the future.
Do you guys see anywhere for improvement to make power or possible suggestions on places to get these at the best prices?
All input is appreciated, thanks in advance!
I think you're on the right track with your exhaust plans, that's an expensive setup, but those will give you the best gains...
Intake-wise, a bigger lid or volant setup is good, but if the car is 2001-2002, you'll already have the LS6 intake mani, so might not be worth messing with unitl you go H/C...if you're set on changing the intake, I wouldn't go any bigger than a FAST 92/92 setup, it will support virtually any H/C setup and the 102mm probably isn't worth much over that with 346ci...
you'll also wanna get some subframe connectors to reduce chassis flex and lower control arms to help the car hook up
good luck with the build!
Expensive on the exhaust isn't a huge deal because I know it'll speak for itself when done, or at least that's the plan haha
Are there any cons with going 102 over 92? I hear that the 102 makes slightly more power in the end.
Also, either way, if I went 92 or 102, what would I need to support those as far as MAF and intake go?
Subframe connectors are on the list! just forgot to add them haha, sounds like those are pretty essential. I'll probably do the rest of the suspension as time goes on also.
Thanks for the input, can't wait to get the car and get to building!
If you go with either intake, I would just go with matching size throttle body, 100mm MAF and lid...
Again these parts will really start to shine when you go H/C or bigger ci
You'll also need a tune to make all that work
I could be wrong though..?
100mm MAF regardless?
Also, what are the different intakes at that size? Not sure what Volant is to be honest.
I definitely plan on going with a dyno tune throughout also to see how she evolves
I guess I could do some of my own research on that Volant
I basically just made this thread because I want to know where to start when I get the car and I want to be able to hop on deals if they come across
Looks like the stock MAF connects directly to the Y-pipe that connects to the filters... hmm
Not sure what to think about that.
Any ideas on what else that would work with the 100mm MAF?
After looking into the Kooks exhaust and headers it's looking like they claim that their dual exhaust only works with their headers...
I thought I read about some trouble installing Kooks headers before, anyone heard of that or how much less power they make compared to the ARH?
I'm super excited for this exhaust system... looks like it's going to run me $3k or more
Oh well.. gotta pay to play and if I'm gonna keep it nice I guess that's what I'll have to do.
Does anyone know any other sites that may be cheaper for a Kooks headers and full exhaust setup, no cats and dual tips on each side?
Also, I've watched on youtube, but are there any real differences in catted vs non-catted setups on these cars as far as rasp or drone goes?
Kind of hard to tell on youtube sometimes.
as far as cats: if you don't need to stay emissions legal, don't mind rasp, or extra exhaust odour, then forget the cats...the cats will cut down the rasp & smell, keep you emissions legal, but might rob a couple HP
I'll probably just go straight Kooks for headers and exhaust to make it simple and unless I'm near 500whp I don't think the power differences will be noticeable compared to ARH.
I want this to be my fast/cruiser/show car.. I'll get something else for a huge build, procharger or turbo build.
I'm kind of having a hard time on the Cats though, wondering how bad the rasp will be..
I guess it would probably be cleaner to add cats in the future than remove them.
