Interesting problem- update please help
Old Jul 25, 2013 | 09:43 AM
Mzenon88's Avatar
Default Interesting problem- update please help
For the past 3 days my car has been going crazy my gauges are freaking out abs inop light brake light long story short my dash looks like a Christmas tree. The tach and speedo will fluctuate randomly they seem to have a mind of its own. Fuel gauge and alt gauge sweep off and on. I tried to post a video on here to show but I'm posting from my phone. Any help would be great
Car
1998 Ss
Bolt ons
Ls6 intake
True duals
Old Jul 25, 2013 | 10:03 AM
Blownbayou's Avatar
battery sounds like to me
Old Jul 25, 2013 | 10:07 AM
ss4chad's Avatar
Sounds like a short, when was the last time you were under the hood working? Did you accidentally loosen a wire and not tighten it back?
Unplug the battery for 30 min, reconnect and see if the problem still exists. if so then do a wire rung and see which one is faulty.
Chad
Old Jul 25, 2013 | 10:27 AM
Mzenon88's Avatar
Installed a yellow top 500 miles ago. Will definitely get it tested.
Old Jul 25, 2013 | 10:29 AM
Mzenon88's Avatar
Chad
Last install was the ls6 intake, problem seemed to spawn out of no where. I have heard possible a grounding issue but I don't know where the block grounds are located
Old Jul 25, 2013 | 11:05 AM
ss4chad's Avatar
Drivers side, behind the head against the firewall.
Drivers side, underneath the car, from the altenator.
Chad
Old Jul 25, 2013 | 02:45 PM
Mzenon88's Avatar
Hopefully the link works here's a clip of what it's doing
Old Jul 25, 2013 | 02:47 PM
Blownbayou's Avatar
damn..... not sure if that is battery. I was thinking you would get a sweep when you turn the key to on
Old Jul 28, 2013 | 12:06 AM
Mzenon88's Avatar
Update- I took the battery out checked my grounds. I did the big three upgrade about a year ago all soldered connections replaced all wires with me 1/0 gauge for alternator and grounds will attempt to re creat the problem in the morning
Old Jul 28, 2013 | 11:05 PM
Mzenon88's Avatar
Old Jul 29, 2013 | 11:35 AM
ss4chad's Avatar
There is a sensor on the tail of the tranny that could have gone bad or is going bad. Pull it out, spray it with some electric cleaner and plug it back in. I would do it with the battery disconected for 30 minutes and then hook it all back up.
I still think you have a ground or wire that is loosely connected and it is giving intermitent signals.
Chad
Old Jul 30, 2013 | 11:50 PM
Mzenon88's Avatar
Chad
As strange as It sounds I found it. My primary wire running from my battery to the starter was of course old and brittle. The sheathing around the wire in places cracked and came off I went out at night and saw the wire arching off of the ac compressor changed the wire and poof no more issues thanks for the help. I went crazy checking every wire for hours to find it gladly it got late and I saw it
