Very strange question regarding catch can?
Old Apr 30, 2004 | 12:33 AM
JS's Avatar
JS
Default Very strange question regarding catch can?
I took a hollowed PCV valve and put it in the driver side valve cover by the back of the cowl.I ran a line to a 3 barbed TEE and the attached the TEE to the pass. side vavle cover.
Next I ran the other side of the TEE to my catch can and then the otherside of the catch can over to the PCV valve/hose going into my intake
I now seem to see about a 6PSI drop in oil PSI?
Is this normal,I went from 41 PSI to 35 PSI at idle?
Is is pulling too much vacum and lugging the motor down?
I might go back to my open breathers,This is strange?
Anyone have any thoughts?
PS
I have the truck PCV,Should I replace it with a regular PCV valve as to let alittle more vacum to take place?
JS
Old Apr 30, 2004 | 09:21 AM
JS's Avatar
JS
Anyone had this happen....
JS
Old Apr 30, 2004 | 10:17 AM
WILWAXU's Avatar
Most of us run the PCV and a catch can, plumbed off the the TB neck.
Old Apr 30, 2004 | 10:20 AM
JS's Avatar
JS
My bad,its in the TB exactly where the factory PCV valve connects,Wilwaxu..
I might try a regular PCV Valve,Maybe the truck valve it too restrictive now.
Old Apr 30, 2004 | 10:22 AM
JS's Avatar
JS
What are u running on your drivers side valve cover Wilwaxu.
Did u plumb both valve covers to a tee and then to the tank and then to the tb.
Old Apr 30, 2004 | 12:11 PM
WILWAXU's Avatar
My PCV system is stock 2001 with the AMW kit. (did replace the pcv valve couple months back)
The AMW kit basically adds a hose from the tb side of the pcv valve to the can, then from the can back to the tb neck on the intake.
Old Apr 30, 2004 | 02:26 PM
JS's Avatar
JS
But whats in your drivers valve cover....
Old Apr 30, 2004 | 05:07 PM
WILWAXU's Avatar
What ever came there from pontiac
