Can I make more power?
Exhaust would probably have some room for improvement, especially if you hate the sound anyway. Either a large y pipe into 4" single or 3" duals all the way.
What did it make/run so far?
Id probably just leave it alone. Maybe think about the pulley, not sure if you would need a retune after a pulley swap tho.. I saw a few threads where people did the EWpump and gained nothing.
You already have a good foundation of heads, cam, intake, and headers. Now it's just time to tidy up the little things depending on if they're worth the cost to you.
underdrive pulley should get around 5hp, you will notice it rev quicker
duals I wouldn't be surprised to see close to 10hp, lose ground clearance
opening the intake to 85mm likely less than 5hp, maybe more if the whole intake gets properly ported (same goes for switching to a 90/92)
a good lid and ram air may or may not show hp but should be good for a tenth or so and a MPH at the track
some 4.10 gears will likely be the biggest SOTP gain and bang/buck since you have stock gears...everyone I know who went from those to 3.90s-4.10s has been very pleased
Nitrous will do the trick also
