What length bolt for th350 crank spacer?
Old Aug 19, 2013 | 01:47 AM
Redchevyman's Avatar
Default What length bolt for th350 crank spacer?
I bought a spacer to use a th350 on my 5.3 engine. I bought it from GM with the bolts they recommended. The problem is the bolts are the same length as the old ones that hold the flex plate on. I only have 1/4" of threads to hold the spacer. That is only 4 threads. There is no way I can tighten this without stripping the crank hub.
The spacer is 10mm thick so I would expect the new bolts to be almost 10mm longer.
The bolts I bought are 11mm 1.5pitch x 23mm long shoulder to end just like the original flex plate bolts..
I figure I need 30mm long or more to equal the holding strength of the original bolts.
Does anyone know what length bolt I need?
Old Aug 19, 2013 | 02:31 AM
Fast86z's Avatar
Check the jegs we site. Pretty sure they list the size.
Old Aug 19, 2013 | 08:34 AM
Jegs sells the same 1" (23mm) bolts as GM.
Everyone that sells the spacers copy's and paste the same description. They all say you need longer bolts but sell you a 1" long bolt.
Old Aug 19, 2013 | 06:13 PM
S10xGN's Avatar
IIRC, it takes a manual trans flywheel bolt...
Old Aug 20, 2013 | 10:09 AM
The manual trans uses the same 23mm long bolt.
I would like to hear from someone that has used the spacer.
Old Aug 20, 2013 | 08:14 PM
S10xGN's Avatar
Well, I do have that spacer on my swap, and I did use the manual trans bolts...
Old Aug 20, 2013 | 08:27 PM
Did you use GM or ARP bolts?
Old Aug 21, 2013 | 08:39 PM
S10xGN's Avatar
I'd prolly go with ARP on a manual, but with the auto I used GM bolts...
Old Aug 21, 2013 | 11:50 PM
I found out that Chevrolet Performance advertised the wrong bolts with the spacer. I found the right bolts that are 3/16" longer at the local dealer. 19257940 is the part# for those of you that are having the same issue.
