Steam ports
Old Nov 7, 2013 | 05:00 PM
Skunkedtsi's Avatar
Default Steam ports
I recently broke my steam port @ #7 looking at replacements they seem somewhat excessive in the aftermarket world. Can I just simply cut off the tubing from the little parts that bolt to each corner and tap them to say like an 1/8th NPT to a barb and run it that way? See any issues or concerns doing it that way or should I just buck up and spend the 200 on the cnced little AN adapters?
TIA
Old Nov 7, 2013 | 05:50 PM
91lscoupe's Avatar
also wondering this?
Old Nov 7, 2013 | 06:07 PM
one fast zo6's Avatar
easy to make what you want if you use your brain.
Old Nov 7, 2013 | 06:24 PM
Skunkedtsi's Avatar
I proposed what I intended to do, I know I can make it. What I am asking is if anyone foresees an issue, with what I was intending.
Old Nov 7, 2013 | 06:44 PM
jrpimp00's Avatar
Should have no problems, all it is is a port for steam to escape back to the radiator and turn back into a liquid
Old Nov 7, 2013 | 07:20 PM
sparkwirez06's Avatar
http://s41657.storefront-solutions.c...l.aspx?ID=3289 these are reasonable.
Old Nov 8, 2013 | 03:44 PM
Skunkedtsi's Avatar
Perfect! That's what I was assuming, but I wanted to make sure before I spent the coin on npt to a/n adapters and associated lines there wasn't more to it that I was missing. I plan to hook all 4 together and have them terminate into the water pump.
Thank you,
Tyler
Old Nov 9, 2013 | 12:08 AM
99Bluz28's Avatar
KRC power steering makes a set with -4AN fitting on them.
https://ls1tech.com/forums/17041072-post129.html
Old Nov 10, 2013 | 09:37 PM
aburdue's Avatar
Try these. They have the line outputs on the sides like the factory.
Alt URL: http://www.ebay.com/itm/LS1-1-8-COOL...-/131012643191
Old Nov 11, 2013 | 12:24 AM
01ssreda4's Avatar
Ever solder copper pipe? This works on the coolant lines also. You can block them off, repair them, whatever.
Old Nov 26, 2013 | 11:21 AM
Skunkedtsi's Avatar
Thats a good idea but in the way it broke off in the little block I am not sure I could repair it properly even if I had the skills, the tube pinched and is mis shaped now. I ended up building my own with those little an adapters.
Old Nov 28, 2013 | 12:12 AM
97WS6SCharged's Avatar
Originally Posted by sparkwirez06
I bought a set of those and they work great.
