ls6 intake problem
Old Nov 8, 2013 | 11:22 PM
Arctic_Z's Avatar
Default ls6 intake problem
I have a ls6 intake that was ported for a 85mm tb. the inner edges that hold the gasket into place normally have been shaved down. the gasket holds itself into place around the top but i put some gasket maker around it to hold it on and let it dry, seems to do the trick. I bolted my tb to it to smash the gasket to see if that will work. I'm concerned if it will be safe to run it with the gasket exposed? I've pushed on the gasket from the inside and it seems to be in there good... should I run it this way?
Thanks
Old Nov 9, 2013 | 12:22 AM
99Bluz28's Avatar
IMO, I'd probably just make a gasket with some Fel-Pro - Gasket Material.
This way you don't have any worry about it possibly getting sucked into the heads.
Old Nov 9, 2013 | 06:29 AM
RezinTexas's Avatar
I would not run that, its just asking for a vacuum leak
Old Nov 9, 2013 | 07:31 AM
Old Geezer's Avatar
^^^^^ Me either.
Old Nov 9, 2013 | 12:15 PM
Arctic_Z's Avatar
So paper gasket would be better? Doesn't seem like it'd seal to me
Old Nov 9, 2013 | 06:19 PM
2000PewterT/A's Avatar
X2, Literally took the words out of my mouth.
Old Nov 9, 2013 | 08:19 PM
99Bluz28's Avatar
Gasket material is available in a variety of materials other than pure cellulose-fiber. If you're content with your fix that's your choice; but it sure wouldn't be mine.
Old Nov 9, 2013 | 08:24 PM
jsteele90's Avatar
cut your own gasket.
Old Nov 10, 2013 | 11:19 AM
LilJayV10's Avatar
Doesn't professional products sell a 85mm T/B paper gasket?
Old Nov 10, 2013 | 02:50 PM
99Bluz28's Avatar
You're right !
Here's the part #: 69416
http://www.summitracing.com/parts/PFS-69416/
Old Nov 10, 2013 | 03:07 PM
LilJayV10's Avatar
Good find. I looked earlier but only on Google and had no luck. I only found it with their adapter plate. Hopefully that will help the OP out.
Old Nov 10, 2013 | 03:28 PM
99Bluz28's Avatar
Yeah, I had to go to the P.P. website to find.
Old Nov 10, 2013 | 03:40 PM
LilJayV10's Avatar
LS1tech. People helping people. It's a beautiful thing.
OK I'm done.
Old Nov 16, 2013 | 06:11 PM
Arctic_Z's Avatar
wow thanks for the help, I was about to get some expoy and fill the edge in a little and sand it so there was more of a flat surface. Im going to try the 85mm gasket first, save me some sanding. Hopefully the outer edge is enough to make it seal
Old Nov 16, 2013 | 09:42 PM
LilJayV10's Avatar
Let us know how it works out.
Old Nov 23, 2013 | 11:32 AM
Arctic_Z's Avatar
the #69416 85mm gasket came in and it fit good against the intake. I think it should work with no problems. thanks for all the help guys!
Old Nov 23, 2013 | 01:43 PM
99Bluz28's Avatar
Good to hear, and hope it works well!
BTW, you can always coat the gasket with a thin layer of rtv sealant if needed.
Old Nov 23, 2013 | 08:51 PM
LilJayV10's Avatar
Sweet.
