Modifying timing cover for easy cam adjustment
What if I modify stock LS1 front cover to allow access to cam gear bolts, to allow to adjust cam timing? 2" or even smaller round opening would do the trick. Then cover it with larger aluminium sheet on 3 bolts.
Any cons to this?
Besides, there would be minimum .8" gap if I just cut it, to much to RTV, imho.
I guess I'll just leave it as it is, with no possibility to adjust cam timing
P.S. studderin, I was thinking exactly about stacking WP gaskets for easier fit )
