earl's header gasket?
Old May 9, 2004 | 10:47 PM
1dirtyZ's Avatar
Default earl's header gasket?
any one know where i can find some earl's header gaskets? (the ones with soft aluminum inserts)
do they even make them for ls1's?
any suggestions when it comes to header gaskets? i just replaced my stock ones and the leak came back again, for the record its a blown motor.
Old May 10, 2004 | 05:24 PM
WILWAXU's Avatar
Being a blower motor shouldn't have anything to do with an exhaust gasket...
are these stock GM replacements your "blowing" out?
Old May 11, 2004 | 01:29 AM
1dirtyZ's Avatar
yup.
i'm thinking since the motor pushes so much cfm, it might be more prone to leaks ( it used to blow out the collector gaskets).
Old May 11, 2004 | 09:54 PM
1dirtyZ's Avatar
any one?
Old May 12, 2004 | 07:46 PM
ChevyGoldfinger's Avatar
Jegs sells a set of header gaskets made by "Percy's" that are called "Dead Soft" Header Gaskets. Made of something they call dead soft aluminum.
Jegs' part # for the ones specific to the LS1 is 760-66032 and they cost $34.99 per pair. Might just be worth it if they prevent leaks. HTH.
Old May 12, 2004 | 08:23 PM
1dirtyZ's Avatar
thank you very much!
JDPZ28's Avatar
I've got the Percy's dead soft gaskets and they work great IMO.Never had a leak.
Old May 12, 2004 | 11:47 PM
1dirtyZ's Avatar
are they thicker than the stock ones?
Old May 13, 2004 | 11:40 AM
WILWAXU's Avatar
umm.. once again, cfm shouldn't have anything to do with it. If it was a turbo setup.. maybe...
My guess is either a warped flange or they are coming loose.
Old May 13, 2004 | 12:37 PM
1dirtyZ's Avatar
i'm leaning towards the wraped flange theory, cause the bolts are tight.
but why would it leak only at high rpm?
