Can my stock rear-end handle this?
What's up, havent been on here in a very long time. But i have my next project and was wondering if my stock rear-end can handle the extra torque and horsepower and your opinion the kit i slected.
I want the Trick Flow Head Cam kit.
cam 220/224 @.050" .575/575 lift
(TFS-k306-500-460) summit website
and the intake
Fast lsxr 102mm.
and the intake
Fast lsxr 102mm.
and the intake
Fast lsxr 102mm.
and the intake
Fast lsxr 102mm.
im auto. im trying to update my signature under my posts but wont let me.
Im auto my last up grade was LT pacesetter air/egr delete Texas speed catted hi-flow y pipe n frost tune.. im guessing i sould have 350+ RWHP and 330-340 RWTQ
car wise ive taken great care of it. only 98,XXX miles
I'd let Martin @ www.tickperformance.com spec the cam. He can also give you more help on rest of your set-up VS. a generic kit such as the Trickflow setup.
Its basically luck of the draw, I am making 430whp in my 3300lb Monte on a stock 7.5 10bolt. But I have a disability since I have a 26spline rear vs you Fbody guys with the 28spline and I am a 6 speed car as well. I don't power shift or dump the clutch being abusive but that doesn't mean I don't baby the car either. I also run 18x9.5 rear wheels with 275/35-18 Nitto NT-05's so there is some traction available as well.
Its not a matter if will it, but when.
Depends on your intentions for the car. Daily driver yes you will be fine if that is all you are going with H/C/I on a otherwise stock car. I know because I can speak from experience not just internet talk. Just like anything its how well you maintain it/ to what level you abuse it before it breaks
my goal is to try to get 450+ rwhp. after this year ill save for the upgraded rear-end..and transmission. also forged bottom end
