LQ4 Miata IAC getting stuck closed
Old Feb 23, 2014 | 07:54 PM
SnowmanLC's Avatar
Default LQ4 Miata IAC getting stuck closed
I have an LS swapped 1990 Mazda miata, i havent drove the car much just backing it out and back in the garage. Every once in a while it wont start or it will be idling and it will die. The IAC will fully close and wont allow any air in, if i pull off the sensor and push the pintel back to fully open, the car will start and run fine. I was wondering if any one know's what is causing it to fully extend and not retract. Thanks, Chase. I have also replaced it twice,so it is a brand new IAC valve
Old Mar 6, 2014 | 09:19 PM
SnowmanLC's Avatar
Bump!
Old Mar 6, 2014 | 11:00 PM
97WS6SCharged's Avatar
Have you pulled the TB and cleaned the IAC passages thoroughly? Sounds like it's getting stuck.
Old Mar 6, 2014 | 11:23 PM
SnowmanLC's Avatar
Yes the passages are completely clean
Old Mar 12, 2014 | 07:59 PM
SnowmanLC's Avatar
I checked the voltage and its reading 10.7v, does that mean its a PCM issue?
Old Mar 12, 2014 | 08:28 PM
SnowmanLC's Avatar
today when i started the car it idled fine, then when i started it to move it back in the garage it idled fine and as i began to start pulling in it wanted to die so i gave it some throttle to keep it alive then it backfired one time and then died. It started up again like the iac stayed open. On my scan gauge it was reading 16ign timing and my wideband was between 12.6 and 13.0, does the timing sound right for idle or around 1500rpm?
Old Mar 12, 2014 | 09:49 PM
jimmyblue's Avatar
Moderator
IAC valve is a 4 wire stepper motor, its voltage is not
the deal - phase relation between two drive-pairs is
what moves it forward or back.
For the pintle to move like that, has to be either coming
from the PCM or some kind of crazy electrical spurious
action.
One thing to check in the tune is that IAC park position
is not "0". If it is then if the PCM thinks it's shutting off
it will try to drive it closed.
When it has this brain-fart, what does the scan tool say
is IAC Counts? If it thinks it's still open, when it's closed,
that's insanity that needs chasing; if it's going to zero by
intent and it knows it, then you have to figure out why
it wants no air.
Makes you homesick for an idle air bleed screw, doesn't it?
Old Mar 13, 2014 | 11:18 AM
That is fairly normal. There is no 5v signal to the IAC, there are only two 12v sources and two grounds which the pcm controls to move the plunger in or out.
Have you scanned the car with HP Scanner or something similar to see what IAC counts the PCM is demanding and what it is actually doing?
Old Mar 13, 2014 | 03:14 PM
SnowmanLC's Avatar
No i havent, i had a friend with hp tuners but he got rid of it a couple months ago. Looking into getting one soon. I unplugged the iac and the car seems to run fine so far, just idling a little high because of the position of the pintel
Old Mar 13, 2014 | 04:53 PM
jimmyblue's Avatar
Moderator
That (if it remains true) points to a brain-fart kind of
problem, not an IAC problem. Because if you do nothing
to the IAC electrically, it just stays where it is.
Old Mar 13, 2014 | 11:43 PM
SnowmanLC's Avatar
Today i left the IAC unplugged and drove the car to the gas station. After leaving on my way home all of a sudden it leaned out, my wide band was between 18-20. So i pull over and immediatly shut the car off. I call by bro n law to bring his scan tool, it didnt throw any codes that determine why it leaned out. So i started the car again and we were looking at the map and MAF tables, the map seemed to be reading correctly but the MAF was reading way low. It is a brand new maf, going to get a new one tomarrow and see what she does
Old Mar 15, 2014 | 02:16 AM
MadFirehawk86's Avatar
action.
it wants no air.
Where was this reply when I was having IAC issues??
Old Mar 15, 2014 | 02:21 AM
My IAC pintle doesnt move AT ALL and is stuck in the fully open position with the idle at 2000 rpm. I simply cannot find out what is going on....the harness checks out fine with all four wires (from the IAC) having continuity at the PCM connector. New IAC valve and TPS.
Care to add any input on this anyone??
Old Mar 17, 2014 | 09:59 PM
SnowmanLC's Avatar
I put my buddies MAF on my car so i knew it worked, car still leaned out after idleing in the garage for about a two minutes. Everything seems to be reading fine but as i was looking at the scan gauge the car stays in open loop, also the car will pull timing all the way back down to 7 degrees and causes it to backfire. Sounds like an issue in the tune like its locked in open loop, Anyone have anyother ideas?
Old Mar 20, 2014 | 05:10 AM
Hard to say why it's leaning out and pulling timing without any data.
Old Mar 20, 2014 | 09:32 PM
SnowmanLC's Avatar
I just got HPtuners today, going to do some data logging.
