Aftermarket Throttle Bodies.....
Now days, are all after market throttle bodies created equal? Lets say all 92mm. BBK, Nick Williams, Holley, Edelbrock, FAST.... given that they all come in a 92mm version, are there any performance differences? or even design differences in the interior of the throttle body I.E. the blade or the inlet holes?
I had a slight hanging idle issue with it. but it ended up being that the throttle cable was just a touch too tight. I adjusted the cable and it runs 100% as good as stock now.
That's MISTER MODERATOR
The 90 degree vacuum fitting at the top is a plastic threaded fitting just pressed into a smooth bore hole. While I'm sure this is just fine, it kinda bugged me.
I put a 1/4 inch pipe thread tap to it and gave it a thread. As this smooth bore is pretty shallow, I ground the tap point down to make it a bottoming tap.
I have a swivel AN fitting for it.
Ballistic Speed's website is still a blank page.
