mushroomed intake manifold blues
Old Jul 1, 2014 | 11:27 PM
95_lq4_z28's Avatar
Default mushroomed intake manifold blues
I got a used intake manifold. And after receiving it I see the all the plastic around the bolt holes. Is there anyway to cut and redo this?
Old Jul 2, 2014 | 07:28 AM
vettenuts's Avatar
Sounds like someone used ft-lb instead of in-lb when installing. I would be more concerned with cracks if it was overtightened to a large degree.
Any photos of the damage? I would also contact one of the ls1tech vendors who might have some better ideas on what could be done to salvage the intake.
Old Jul 2, 2014 | 08:40 PM
S10xGN's Avatar
Don't these manifolds have steel sleeve inserts to prevent this?
Old Jul 2, 2014 | 09:33 PM
Paul Bell's Avatar
That's MISTER MODERATOR
It's not a piston. It's not a crankshaft. Yet this is the internal engine section?
Old Jul 2, 2014 | 10:14 PM
LS1-450's Avatar
Talk to the seller about it if you're unhappy w/ the manifold.
Old Jul 22, 2014 | 10:49 AM
skiziFiziks's Avatar
If I recall correctly only two are sleeved, one per side, diagonally opposite from each other.
Makes you wonder though just who is sitting there tightening bolts with their eyes closed haha.
Old Jul 22, 2014 | 11:32 AM
jimmyblue's Avatar
Moderator
I think I'd just put some washers over the mushroomed
areas. Maybe stack a hard over a rubber washer if there
isn't a nice planar surface anymore. You only need to keep
the O-rings softly compressed and the torque-down,
uniform.
Old Jul 22, 2014 | 01:03 PM
Fry_'s Avatar
^^^ I had the same idea when I read the first post. Should work fine as long as there are no cracks that could cause vacuum leaks.
Old Jul 22, 2014 | 06:25 PM
Old Geezer's Avatar
Thumbs down Doesn't make much
difference, Paul. It's the first forum, and catches every "whatever thread".
If the Drag race forum was moved to the top of the list, it would be full of unrelated threads...
Start deleting them, and maybe some would wake up, and read the stickies..
