Since German Castrol is gone.... (IT'S NOT!!)
http://www.machinerylubrication.com/...il-technology-
http://www.synlube.com/synthetic.htm
Pennzoil starts with Pennsylvania crude - a dino oil. Nothing synthetic about it. Then it's refined enough to meet certain performance characteristics so that the FTC will allow it to be called "Synthetic". A legal trick of marketing, and nothing more.
These so-called synthetics are not bad oils. Some of them are slightly better than standard dino oils. For the average street car, they're probably more than you really need. But if you're paying more than $5 or so a quart, you're getting ripped off (IMO).
What would be my best choice. My car has approx 55k miles. It's a weekend toy and is mostly stock except for off road exhaust and a custom grind FTI StreetSweeper cam. My cam card says to use oil with higher zinc.
My local Wal-Mart Stocks Pennzoil Ultra in 5 qt jugs for 27.00 and M1 for 25ish every day of the week. They also stock Fram ultra filters. My local Advance Auto is always running a great deal on oils but varies month to month.
I used to use GC back in the day...but only some AutoZone's here had it on occasion and it rarely went on sale so I switched to Pennzoil Platinum and then Ultra. The last time I changed the oil (probably 2 years ago) I used 6 qt. of Ultra 5w30 and a WIX 51522. Although I'm sure it's still a great oil, it's my understanding Pennzoil Ultra SN isn't as good as the SM was. Someone correct me if I'm wrong.
I went by Advance Auto to see if they were running an oil/filter deal and get a jug of Mobil 1 0w40 and a Fram Ultra filter as recommended to me by a member on here and LS1tech.com. Right now they're having a deal on Castrol Edge Syntec which includes the 0w30 Euro Formula. 5 quarts for 32.99 plus a free Pure One filter or pay 2.00 more and get a K&N or Fram Ultra filter. Plus they give you 10.00 back in a rebate card. Most of the qts are made in Belgium, but they have several that is made in Germany.
Is the 0w30 still as good as it used to be and does it matter whether it's from Germany or Belgium anymore?
If so, should I stock up on this while there's a deal or would it be worth it to switch to M1 0w40?
Also, of the 3 filters, which is the best?
If the Castrol is still good stuff I'll switch back to it...especially at this price. If the M1 is better I'll switch to it and stock up when there's a sale on it in a month or two.
What do you recommend?
Synthetic oil has two major advantages. First, it can handle a lot of heat for a long time without breaking down. That's important with sustained high rpm's, like road racing. And with air/oil cooled engines, like a Harley or VW.
Second, they have really long drain intervals. If you drive 15,000 miles a year, you can do an oil change once a year.
Bu for the average week end toy that only see's 5-6K street miles a year, synthetic oils are a real waste of money.
As for filters, I use Purolater Pro-1. Fram is probably one of the worst filters on the market.
Having said that, there's plenty of better filters out there, I stay away from any and all Fram oil filters.
The cheapest filter I use is a Mobil1 extended. I stock for my vehicles Fleetguard StrataPore filters.
Let's keep this on oils people, this is a discussion about replacing German Castrol.
Either way, I won't run RP in my stuff because it's too damn expensive and not necessary. If I had to pay full price for Castrol I wouldn't buy it either. If I get Castrol Syntec on sale it's $30-35 with a good filter. That's not much more expensive than using name brand dino oil and having to buy a good filter.
At the end of the day, "what oil to use" might be one of the most over stressed worries for no good reason. Especially since most of the people asking change it prematurely in the first place. Several guys on here have admitted to changing synthetic oil at under 3,000 mile internals which is just wasteful (assuming the car is not stored or often started and not allowed to reach operating temp).
I believe last time I looked our oil prices at WalMart here even the store brand was $13 for 5 qts and most dinos were around $15. But doing as you suggest would be a good deal.
Just loaded 7 quartz into the Hemi yesterday...but I only use HPS with RP . R P said that the HPS can last longer than their regular synthetic oil because of a better additive package they added to the oil.. I can't confirm that but new gen Hemi are known to have that "Hemi Tic" and the stroker in my truck doesn't "tic" with HPS.
.I haven't found a store that carries it so it is ordered in..
All my other cars have Mobile 1 Syn.. with either a Mobile 1 filter or a Wix filter
5W30 Synthetic Oil Comparison Chart
I'm having a helluva hard time finding info on the Joe Gibbs oil.
And the Rotella info I found was for PC1303, I need to find out if that is their T6 oil or another branch of their 5W30 lineup
Some of these guys make it so damn difficult to get product information
I found a much better and detailed oil test result page, in for a long read?
http://speedtalk.com/forum/viewtopic.php?f=1&t=30483
